Flush Mount Tail Light Kit
Old Oct 27, 2004 | 09:31 PM
ROJ#79's Avatar
ROJ#79
Default Flush Mount Tail Light Kit
Anybody that has installed the flush mount kit, do you think it's a good idea to drill a small hole at the bottom of the housing to let the water drain out?
Old Oct 27, 2004 | 09:34 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
I like the idea of the flush mount kit. I actually have one waiting to go on. I just can't find the long torx screws. I do not like the ones that were sent with the kit. I personally wouldn't drill a hole, because one day you may not want the lights to be flush. Good luck
Old Oct 27, 2004 | 09:40 PM
ROJ#79's Avatar
ROJ#79
You would not see the hole , it would be hidden by taillight assembly>
Old Oct 27, 2004 | 09:43 PM
ROJ#79's Avatar
ROJ#79
The hole wouldnot be seen as it would be hidden by the tail light assembly
Old Oct 27, 2004 | 11:25 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
I would not drill a hole, the water should just either flow out of the backside of the tail lamp or out of the front. BTW, you can paint the head of the longer screws that came with the kit. Mine looks just fine.
Old Oct 28, 2004 | 09:20 AM
QuikZilver's Avatar
QuikZilver
I installed this kit on my 01 Z. I have no problems with water collecting at the tail lights, so I wouldn't drill any holes.
Old Oct 28, 2004 | 09:35 AM
Reuvn8r's Avatar
Reuvn8r
Cruising
Can you guy tell me where to get this kit? Thanks.
Old Oct 28, 2004 | 10:00 AM
VetteHunting's Avatar
VetteHunting
Lots of places. West Coast Corvettes has them.
Old Oct 28, 2004 | 10:02 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
I've drilled 1/4 inch holes that work very well to drain the water and they are not visible at all. Oh yeah, and I do not have flush mounted tail lights. So, done correctly, they will not be visible with or without the kit.
Old Oct 28, 2004 | 10:06 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Holes are not a good idea...
the hole is present on either side of the housing...
...so the motive to drain from the outside works...
and so there is an equal opportunity for dirt, water, coming back through the hole from underneath...
In fact, much of the dirt I clean around the taillights is actually thrown up from underneath StuzVette and ends up under and behind the taillight lens...
Old Oct 28, 2004 | 10:59 AM
Shortimer's Avatar
Shortimer
I have a set waiting to be installed. Just have not found the time. Saw some pictures posted on this Forum and I liked the look. Got them on sale from a Forum vendor.
Old Oct 28, 2004 | 11:21 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '06-'07
got mine from lapd
Old Oct 28, 2004 | 11:22 AM
QuikZilver's Avatar
QuikZilver
Mine are from West Coast Corvettes.
Old Oct 28, 2004 | 12:58 PM
Don't think I would drill any holes. Just another place for moisture to get in also.
To Flush Mount Tail Light Kit
