Thinking of adding Rocker Rails from A&A. Do they cover the area where the Jacking Pucks are placed for jacking up the car.
I know that I can use the rocker rails for jacking once installed, but I am more concerned about the ability to trailer the Vette and utilize Trailering hooks at the location where the jacking pucks meet the frame.
Thanks for the update. Did you install them yourself or have someone do it. I have a 4-post lift and will attempt it myself if it is not too difficult.
Also, did you install the Frame Savers? And, did you have them welded or not.
I installed mine on ramps. You need enough room to get a drill under the frame to drill several holes in the frame for the rails. Not sure if your lift would allow you to get a regular drill in there with the main ramps. I also installed the frame savers also but didn't weld them. That's optional but obviously makes the install more robust.
