Code vanishes???
Old Oct 29, 2004 | 09:48 AM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
Default Code vanishes???
While driving yeaterday I got a check engine light. Checking the codes I found "PO455" displayed. I cycled through all of the historical codes and deleted the old ones. While doing so I erased the PO455 code as well. I was told that if I did this the current code would reappear. So far, after 30 miles of driving the code has not come back.
Is this normal?
Should I get it over to the dealer who will no doubt tell me he can't do anything if he can't see the code?
TIA
Old Oct 29, 2004 | 10:26 AM
JimAgain's Avatar
JimAgain
Had you just filled the gas tank? I'm coming up with:
DTC P0455 Evaporative Emission System Leak Detected
It is listed as a GM code but is not listed on the stengel site for Vettes.
It may not come back. Consider it a blessing.
Old Oct 29, 2004 | 10:28 AM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Scott, I would check to see if your cap is coming lose when you hit the fuel release door. You said it may be coming lose. If so I would get another cap from the dealer. Thanks again for the endlinks.
Chris
Old Oct 29, 2004 | 10:50 AM
ErnieD's Avatar
ErnieD
St. Jude Donor '16-'17,'19
I saw the P0455 code on my 2004 coupe one time about 1000 miles ago -- check engine light stayed on. After identifying the code, I reset it and it has not returned. I have not noticed that my gas cap has been loose, but it seems to take very little effort to remove.
Ernie
Old Oct 29, 2004 | 11:11 AM
VetteSiNz's Avatar
VetteSiNz
I have check engine light came on with P0455 code on my 04. I check my gas cap and it was just hanging on top of the filler tube. I retighten the gas cap and resetted the code - cleared the check engine light.
Old Oct 29, 2004 | 01:13 PM
OrangeVegaGT
Thanks guys. I'll keep a close eye on that gas cap.
Old Oct 29, 2004 | 02:13 PM
HummelS's Avatar
HummelS
That code is consistent with a loose gas cap, according to my service manual for code P0440, which someone posted had been changed on later models to P0455.
Old Oct 29, 2004 | 03:18 PM
GrayC5's Avatar
GrayC5
Also, the diagnostics on your car appear to be functioning normal and as prescribed within my '03 GM Service Manual. The PCM monitors the fuel tank pressure as part of the Evaporative Emissions System test. I too believe this may be connected to the loose gas cap problem you reported in your other post. Good luck!
Old Oct 29, 2004 | 06:41 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
I believe P0455 designates a large vapor leak in the sealed fuel system. The best thing to do whenever a P04** code is received is to reset, and drive a few hundred miles to see if it resets. That is after you cycle the cap on/off first.
We did some testing a few months ago at the GM Spring Hill Assembly Plant, trying to get a feel for how long it takes for a P04** code to set with the fuel cap completely off. It took close to 55 miles of constant driving to turn on the light, then we reset, and it took another 50+ miles to turn the light back on.
Problems that can cause these P04** codes to set include the fuel cap not on correctly (three or more clicks), incorrect fuel cap, vapor line loose, cabon canister fittings loose or canister blocked. Large leaks usually are attributed to the fuel cap being completely off, the vapor relief line off (there is a tube that runs from the tank to the fuel fill pipe to allow pressure to equalize while you fill the tank), or a vapor line completely off.
To Code vanishes???
