My 2002 knocks slightly under WOT using 91 octane gas. What octane level is needed to completely stop the knocking? I have found a station that sells 92 octane but I have not tried it yet.
The car shouldn't knock with 91 octane. The knock sensors should adjust the timing for the octane fuel used. Something else may be wrong.
91 should work fine. I track the car with 91 here in CA (the great state won't let you use anything higher), never had knock with it or with my '00 coupe. I'd check on some other problem.
