[Z06] When Oil Gets Low
Old Oct 30, 2004 | 06:36 AM
hoogbest's Avatar
hoogbest
Default When Oil Gets Low
What kind of oil should I add when oil gets low and not time for complete change or should I just change?
Old Oct 30, 2004 | 08:10 AM
barondw's Avatar
barondw
Your owners manual lists in great detail all the types of fluids that are recommended for your Z06.
I believe its a waste of money to do an oil change if you are a quart low. But the real question is why are you a quart low, or whatever the amount is. These engines, even doing DEs, don't burn oil.
Old Oct 30, 2004 | 10:13 AM
ZO6Les's Avatar
ZO6Les
Mobile 10W30 in a warm climate, 5W30 where it is cold. How many miles on the oil change, and (therefore) how many miles before it got a quart low? You should get at least 3K miles, most get 5K or more, without having to add oil. If you have over 5K miles since the last change and you are low I would go ahead and change the fluids, and while you are at it upgrade the oil filter to a UPF, Mobile 1, K&N or equiv.
Les
Old Oct 30, 2004 | 11:08 AM
Thud's Avatar
Thud
Add some more of whatever oil you already have in the engine.
Old Oct 30, 2004 | 06:40 PM
3XBlack6spd's Avatar
3XBlack6spd
I just did an oil chang eon My Z.....It took 8 1/2 quarts for it to read full??????????? Its supposed to be 6!
Old Oct 30, 2004 | 07:02 PM
mikeo's Avatar
mikeo
I always carry a couple quarts of Mobile synthetic in the trunk to add when needed.
Old Oct 30, 2004 | 08:16 PM
skip89's Avatar
skip89
8 1/2 quarts ?? I think 6 1/2 quarts is in the owners book. It does take awile to drain down to the oil pan....
Old Oct 30, 2004 | 11:11 PM
hotrod323's Avatar
hotrod323
Default oil
Top off with the oil that you are using ( it should be a synthetic). the engines in the c5 and ZO6 use 6 1/2 qts. if you are going to do autocrosses or road racing adding an extra quart (to 7 1/2) is a must.
Old Nov 1, 2004 | 01:33 AM
EHS's Avatar
EHS
Add any oil that maintains the GM spec per the owner's manual.
These engines, under normal conditions, will burn about a quart every two thousand miles.
To When Oil Gets Low
