front end wobble
Old Oct 30, 2004 | 10:26 PM
pdanb's Avatar
pdanb
Navigator
Default front end wobble
my 2000 coupe has a mild front end/steering wheel wobble at 70 mph and above - is this an alignment problem, another problem, or nothing unusual? the tires are new, and I believe the front end was aligned with the new tires, but I am not sure. thanx.
Old Oct 30, 2004 | 10:34 PM
I X L R 8's Avatar
I X L R 8
It could be a number of tire related problems.
Id blame it on the rotors first.
Old Oct 30, 2004 | 10:50 PM
alanh's Avatar
alanh
You got a poor balance job on your new tires.
Old Oct 30, 2004 | 11:17 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
The most likely thing is the tires are not balanced properly. Or it's possible, but not likely, that you have a tire problem.
It's not the rotors ... warped rotors would only be noticed when the brakes are applied (when the pads contact the rotor).
Old Oct 31, 2004 | 01:03 AM
FDA's Avatar
FDA
I recently had the same issue after having mounted a new set of tires. Since you've just mounted new tires, it's very likely that you either got a bad balance job or perhaps have a tire with high spots and is out of "round" in relation to your wheel rims.
Most people don't realize that tires can be moved around on the rim to find the best match or marriage between tire and rims to eliminate high spots. Have this done to provide you with the truest most round ride. One cause is that the tire bead may not be properly seated all the way around the rim.
A good shop that does on the car spin balancing can resolve this issue by moving the tire around on the rim and also reseating the bead. I'd also recommend getting the on car spin balancing to get a glass smooth ride unless you're going to be taking your wheels off the car frequently...
Hope this helps...
Best regards,
FDA
Old Oct 31, 2004 | 01:08 AM
I X L R 8's Avatar
I X L R 8
BULLCHIVIC.
Dont ever ever think it cant be the rotors.
Bad and worn or out of balance rotors can indeed be a culprit.
To front end wobble
