"Must Have" Mods???
Old Oct 31, 2004 | 10:48 AM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Default "Must Have" Mods???
So....I've ordered the easy stuff, a Vararam and Borla Stingers. 4.10's are also on my list, probably have them in the next month....
So....what other "easy" and "bang for the buck" mods are there that should be next for me? I'm not talking headers or internals, I'm well aware therin lies the secret to REAL power without going FI. I'm just asking if there's anything else I should be looking at to add another 10 or so hp? Also, with the Vararam and the Stingers is 375hp (motor) a reasonable expectation (on an otherwise stock 345hp '99), or is that a bit optomistic?
One last thing....please don't turn this into a Borla vs "other" and a Vararam vs "other" debate, I've already ordered them so I'm living with my decision. Not to mention there are already many other intake and exhaust debate threads out there. Or a 4.10 vs other ratios debate, I've seen those too. I'm just looking for suggestions for what "easy" mods are left (if any).
Thanks!
Old Oct 31, 2004 | 12:47 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
floor mats.... and them door lock cover thingies
Old Oct 31, 2004 | 12:51 PM
gyoung's Avatar
gyoung
Yeah - those add lots of horses
Old Oct 31, 2004 | 01:02 PM
X-ZZ4's Avatar
X-ZZ4
Go back to PR&C where you're appreciated.....
Come on guys, is there nothing else????
Old Oct 31, 2004 | 01:17 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
I think at that point, I'd be looking at a predator.
Old Oct 31, 2004 | 01:22 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You might look into LS1 Edit session with your favorite local tuner. Also, can't tell if you have an A4 or an MN6 - if you have an MN6, you might think about an aftermarket shifter like a Hurst or a B&M. It won't add HP - but it will give better shifter feel.
You can always add a couple of "Type R" decals, they're good for another 10HP by themselves!
Old Oct 31, 2004 | 01:25 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Might as well plan on the headers next to add some more kick and get rid of the cats if possible. This would really compliment your exhaust mod.
Then you'll be all set for the internal mods when the time comes.
Old Oct 31, 2004 | 01:37 PM
X-ZZ4's Avatar
X-ZZ4
Sorry....MN6....I thought the 4.10's would have given that away. The shifter is good advice, as long as it has a **** with the shift diagram, I drove one car with an aftermarket **** and I kept forgetting where reverse was...
I don't have any "Type R" decals, but I do have some Autometer and MSD decals that came with stuf I bought for my GTP....will those work for 10hp?
Old Oct 31, 2004 | 01:40 PM
X-ZZ4's Avatar
X-ZZ4
This is Cali...so the cats have to stay.
But I guess maybe headers are the way to go instead of messing around with more bolt ons that may or may not add any real performance......
Old Oct 31, 2004 | 01:45 PM
X-ZZ4's Avatar
X-ZZ4
Good advice. Anyone know what would be best, a Predator or an AutoTap? I've been looking at an AutoTap for sometime for my GTP, and I know it would work on a C5 also. I assume the Predator is for a C5 only (and I saw they're limited to one car as well, is that true, what if I traded this C5 for another?)....
Those familar with both....why would I want a Predator over an AutoTap, or would I? And why?
Old Oct 31, 2004 | 02:35 PM
JACKAL0PE's Avatar
JACKAL0PE
But do you have the ultimate? A high-performance hood seal?
Seriously, I'd also be adding a lower temp thermostat, maybe smaller drive pulleys and the hot water bypass. That's probably good for 5 hp.
Old Oct 31, 2004 | 03:00 PM
PaceThis's Avatar
PaceThis
An LS6 Intake is an easy mod...install should take under an hour...good for 5-10hp maybe...used around $250, new $375. As mentioned, you're going to want headers if you are looking for power...and a dyno tune (~$400) should be good for 10-15hp.
Since you've not yet bought the 4.10's, I might add a suggestion you hadn't thought of...replace the transmission with an MN12 for better gearing instead of the 4:10's. Or do the MN12 with 3.73's for about the same performance. If you get a good buy on one used, it won't cost much by the time you sell your old one...and you can likely get a lower mileage pc in. The install is pretty much the same as it has to come down with the rearend anyway...
Many people say that the aggressive gearing gives the equivalent of 50hp in a 1/4 mile. Plus, your taller gears wouldn't be as aggressive, leaving your highway cruising speeds more tolerable...
Old Oct 31, 2004 | 03:14 PM
X-ZZ4's Avatar
X-ZZ4
Highway cruising speeds? In SoCal? You mean like 40mph?
Seriously though , I drove the thing on the freeway yesterday, and it's barely above idle at 70 in 6th. A & A Corvette tells me it will only be at 2200 at 80 in 6th with the 4.10's. That's absolutely fine with me.
I saw other threads about the MN12. Sounds like a good idea to me. However, I don't think I'd consider it unless my MN6 breaks. Not to mention the car came with a 100,000 mile (from the time I purchased it ) warranty on catostrophic engine or tranny failure. And yes, I asked if that is still valid with mods and the answer was "yep, nothing but a turbo or supercharger will void it".
Old Oct 31, 2004 | 07:26 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Two words. Kooks Headers.
Old Nov 1, 2004 | 12:31 AM
mdhmi's Avatar
mdhmi
Borla Stingers, 4:10 gears, and a VaraRam are all the bolt-ons you need. Get a tune and call it quits untill your ready to spend another couple grand on headers or cam. Or, skip the headers and go twin turbos.
Cheers,
Mark
Old Nov 1, 2004 | 07:07 AM
How about some headers for the car? Would give you some HP. Also, consider an LS1 edit tune once you get anything else on the car. It can add a few horses.
Old Nov 1, 2004 | 08:09 AM
davisce's Avatar
davisce
Default Bolt On's ~ “Over Optimistic”
84zz4Vette,
Just my opinion, but I think you’re being a little “Over Optimistic” with the HP gains (375 hp) you are expecting with 4:10 gears, “Stingers”, and VarRam Air Intake. I would put the hp plus-up in the neighborhood of a 10 – 15 max.
Tuning would help to maximize the hp your engine can produce without any additional MODs, but realistically the MODs you’re adding I would say you can expect your hp gain (up from the stock 345 hp) to be around 355 hp to 360 hp ballpark (max).
You said you didn’t want to hear about “headers”, "Heads", “cams”, or any of that other stuff, but without them you aren’t gonna get the “HP's” you’re talking about.
Now, the 4:10 gears will give you that “neck snapping” feel going through the gears, but again the hp gain you’re looking at won’t be much more than 10 or 15 max.
Anyway, hope everything works out ! Get that "tuning job" to real find out what the HP gains are.
Later,
Cecil
German American Corvette Club
Of Baden-Wurttemberg
Heidelberg / Mannheim, Germany
Hometown: Boren ~ Alex. Virginina ~
But call Fort Laurdale, Florida home these days.
To "Must Have" Mods???
Old Nov 1, 2004 | 08:34 AM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
Old Nov 1, 2004 | 09:07 AM
Radarmanz28's Avatar
Radarmanz28
How is 4.10 gears a HP adder? You gain ZERO HP with gears, acceleration sure but no HP.
Old Nov 1, 2004 | 09:34 AM
X-ZZ4's Avatar
X-ZZ4
Guys......I KNOW gears don't add HP. I also know what gears can do for perfomance. I may be new to C5's, but I'm not new to cars, plenty of good old fashioned hot rodding experience here.
And like I said, I KNOW headers and internals are the key to REAL HP.....
The purpose of my question was to find out if there's any other "easy" mods I'm missing. And with the exception of a tune, it looks like the answer is probably "no". Time to start saving for headers........
