all power cuts out while driving?!?!!!!!!!!
Old Oct 31, 2004 | 11:49 AM
goldlifter's Avatar
goldlifter
Default all power cuts out while driving?!?!!!!!!!!
i just bought a 98 m6 coupe and the first week it performed fine and this week sometimes the car won't start and while driving, all power cuts out momentarily(electrical and mechanical). one time while starting i had the column lock up....any idea what the root of the problem is? as an added note, the previous owner had an aftermarket sound system and left the amp in but replaced the cd face with the factory one and now the speakers wont work as well. any help would be greatly appreciated fellas. thanks in advance, take care
Old Oct 31, 2004 | 12:29 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
...ummmmm....in the words of Dick Cheney...
...I dont know where to start..."
you probably have a number of issues...and I would recommend you get some advice on a good mechanic...
Old Oct 31, 2004 | 12:34 PM
EHS's Avatar
EHS
Could be so many things, like Stu said.
I'd start by going back to the original owner. Ask him what else he took out besides the radio.
You said the speakers don't work. Did you check if you still have speakers, you know, behind the grilles?
All kidding aside, start with him.
Old Oct 31, 2004 | 12:36 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
hmmmm...check your PCM..under passenger footwell...I wonder if the battery leaked and is causing you problems..that or maybe the A/C drain tube clogged and water got in there
Old Oct 31, 2004 | 12:51 PM
goldlifter's Avatar
goldlifter
lol, i should have elaborated...in the two way speakers, the tweeter is working but the woofer is not
yeah, i plan on taking it to my mechanic on monday and get his thoughts on the situation.
Old Oct 31, 2004 | 03:08 PM
JC in XTC5's Avatar
JC in XTC5
Could be a loose ground in the PCM. It's under the battery, not footwell (that's the BCM). But since it sounds like the previous owner was likely touching electrical connectors in removing the amp, etc., I would ask him where they were working and try to narrow down the area - there may be a loose connection or ground.
Check the DIC for codes.
The fact that you're loosing all power for a brief moment would indicate that the PCM is cutting off. If it were water or battery acid on it, the result would likely be more like a confused PCM throwing all kinds of codes rather than just cutting out.
Old Oct 31, 2004 | 04:27 PM
goldlifter's Avatar
goldlifter
actually, it does throw a bunch of different codes regarding the ABS, SES, and traction control
Old Oct 31, 2004 | 04:34 PM
1Patriot's Avatar
1Patriot
Is it a flood car????
Old Oct 31, 2004 | 06:31 PM
goldlifter's Avatar
goldlifter
no, as i have heard of that happening with flood cars
Old Oct 31, 2004 | 11:33 PM
JC in XTC5's Avatar
JC in XTC5
Check under the battery for acid leaking on the PCM. I've heard of TCM and ABS codes being thrown due to a damaged PCM. That would be the first place I'd look.
Old Oct 31, 2004 | 11:39 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
I'll bet your DIC is sore
Start here so when you go to the dealer/mechanic you'll have something to offer
http://www.stengel.net/diccodes.htm
Other than that
I feel for ya, Brutha!
Michael
To all power cuts out while driving?!?!!!!!!!!
