Important Question..
Old Oct 31, 2004 | 07:22 PM
Jeremy2792's Avatar
Jeremy2792
Default Important Question..
I put 6 Quarts in on my last Oil Change. A couple days later (Today) I saw smoke??? Was 6 Quarts too much? What should I do?
Old Oct 31, 2004 | 07:27 PM
BigJoe's Avatar
BigJoe
I believe they take 6.5, so 6 is not too much. I'd keep an eye on it. Does it use oil between changes?
Old Oct 31, 2004 | 07:29 PM
GrayC5's Avatar
GrayC5
The capacity with filter is approximately 6.5 quarts. What does the oil level read on the dip stick?
Old Oct 31, 2004 | 07:36 PM
Jeremy2792's Avatar
Jeremy2792
Let me check
Old Oct 31, 2004 | 07:44 PM
Jeremy2792's Avatar
Jeremy2792
It says it is right where it is supposed to be, right on the arrow.
Old Oct 31, 2004 | 07:53 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Could you have possibly gotten some oil on the manifold?
Old Oct 31, 2004 | 07:54 PM
CN RED's Avatar
CN RED
If you see smoke, if it smells like oil burning you just might have spilled and that the oil burning off.
I don't know if you changed your oil filter but make sure that it was seated correctly. If you did'nt oil might be dripping from the filter.
Lastly check your oil cap and make sure it's on tight. It might be coming from there also.
Oh and 6 quarts is'nt enough to overflow. Some people have put has much as 7 in with no problem.
CN RED
Jeremy2792's Avatar
Jeremy2792
Could it possibly smoke with out ENOUGH oil? Because I put exactly 6 Quarts in?
Old Oct 31, 2004 | 07:59 PM
CN RED's Avatar
CN RED
No. You putting exactly 6 quarts in is'nt something that would cause the car to smoke.......What color is the smoke?
CN RED
Old Oct 31, 2004 | 08:01 PM
GrayC5's Avatar
GrayC5
Originally Posted by CN RED
If you see smoke, if it smells like oil burning you just might have spilled and that the oil burning off....CN RED
Yep, that was my first thought too - that you might have spilled a little oil somewhere and that was it burning off. I would just watch for leaks and check the oil level regularly for a while. Good luck!
Old Oct 31, 2004 | 08:02 PM
Jeremy2792's Avatar
Jeremy2792
Thanks for your help guys. Ill keep the look out on her when I drive her.
Old Oct 31, 2004 | 08:07 PM
Monster231's Avatar
Monster231
Just smoke the tires everywhere you go and you wont notice the other smoke
Old Oct 31, 2004 | 08:09 PM
DaBoz's Avatar
DaBoz
To Important Question..
