Tire Shine all over car
Old Nov 2, 2004 | 03:38 PM
Ward1's Avatar
Ward1
Default Tire Shine all over car
Does anyone know of a tire shine that does not fly all over the side of the car when your driving? It seems as though tire shine loses its shine after its been drying for a while. I like the wet look.
Old Nov 2, 2004 | 03:43 PM
00hotvette's Avatar
00hotvette
Use a small foam brush. Apply on the brush and not on the tire.
Old Nov 2, 2004 | 03:50 PM
Randy's C5's Avatar
Randy's C5
Just started using the Mcguires (sp?) product from Auto Zone. Goes on like paint and does not end up on the side of the car as you drive.
Old Nov 2, 2004 | 03:58 PM
cob206's Avatar
cob206
St. Jude Donor '05-'06-'07-'08
I do this using Eagle One with the Tire Swipes, let it sit overnight and still get some spray.
Old Nov 2, 2004 | 04:08 PM
wolfman04's Avatar
wolfman04
Zaino Z16 work well for me
Old Nov 2, 2004 | 04:18 PM
Vettman 1's Avatar
Vettman 1
Try "303" applied with a piece of foam rubber. Leaves a nice sheen.. not real glossy.
noel48's Avatar
noel48
St. Jude Donor '14
I've used Meguires,Stoners,Turtle Wax and they all sprayed the side of the car
Old Nov 2, 2004 | 04:30 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
its not the product, it's the application... NEVER spray anything ON YOUR Tires.. it runs down the grooves and get flung off when you drive..
always put your tire dressing on a foam pad.. fold it over and allow the products to spread evenly in the pad.. then rub the pad on the tire.. in tis way none will drip down into the tire channels and grooves anbd remain a puddle of liquid to be flung off at the first centrifical rotation..
I use Meguiars Gel... on a yellow foam pad..and it never flings off..
Old Nov 2, 2004 | 04:37 PM
00hotvette's Avatar
00hotvette
Old Nov 2, 2004 | 04:45 PM
Tom/99's Avatar
Tom/99
I never use tire shine on my tires. I clean my tires with dish washing soap, and a brush. My tires have a sheen to them, not a wet look. But, tha paint stays clean, and so do the wheel wells.
Old Nov 2, 2004 | 04:48 PM
Z0SLIK's Avatar
Z0SLIK
Old Nov 2, 2004 | 05:17 PM
I use Adam's Polishes V.R.T. - available from West Coast Corvettes or the manufacturer. It is applied using a foam applicator. Seems to stay on the tire well, especially if you only put on enough to give the tire a shine. No use putting a huge amount on there.
Old Nov 2, 2004 | 05:25 PM
Crushinator's Avatar
Crushinator
I use regular old Armor All. Spray it on generously then wipe it down. Make sure you get the excess in between the outside treads too. The tires have a nice wet look and zero spray on the side of the car.
Old Nov 2, 2004 | 05:39 PM
C5 ChemE's Avatar
C5 ChemE
I've been tryin to figure this out too!!
I think I've been using Eagle One, spraying it on, and that $hit shows up ALL over the car, ESPECIALLY on MY
Guess I gotta start applyin it with a sponge!!
Old Nov 2, 2004 | 05:44 PM
DsC5's Avatar
DsC5
that and Zaino Z16 work well.
Old Nov 2, 2004 | 06:08 PM
sebringsilver97coupe's Avatar
as stated above, its not the product as much as it is the application. ive tried tons of stuff on mine and if u just put the minimal amount on it and wipe it all in it wont sling off. i personally have most recently used armor all wipes and it works fine. ive tried all of the products though, and u just cant put too much on it cause it will settle in the grooves and then sling off.
Old Nov 2, 2004 | 06:12 PM
VetteMan4Life's Avatar
VetteMan4Life
I spray the tire shine on the tires before i wash the car when they are still dry. I let it sit and soak in for a bit, then i spray off anything that might be left over when i wash the wheels. It works good for me.
To Tire Shine all over car
Old Nov 2, 2004 | 06:49 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Just make sure it's dry and not applied too thick.
Old Nov 2, 2004 | 06:56 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
All tire dressings fling. Some more than others. Nothing you can do. Mequiars high endurance tire gel flings less.
Old Nov 2, 2004 | 07:10 PM
Tino's Avatar
Tino
Default Tire shine
