I am thinking about gutting pre-cats. I want to know how much of a stinch it lets out if i was go gut them and how long does it smell when i start the car. Also what would be the process for gutting them. Any pics of people doing the process and stuff. How much louder does the exhaust get after gutting them?
The car gets louder and you will be smelling gas at stop lights if the wind is blowing your way. What about using high flow cats instead?
VR
VR
so the smell will never go away i thought it only smelled at start up. Do you know where i can get some hi flow cats so i can check out pricing.
i still do not think it smells after startup. I only want to gut the precats so does it smell after i have taken off i thought it only smelled till the main cats warmed up?
I am sorry I miss understood... pre-cats only... well then it may not be a problem for the smell after all... I was thinking along the lines of the 97-99 cars that only had one set of cats on them.. You can get High flow cats from these people here... http://exhaustproslinc.com/magpolstains.html
VR
VR
can any one help me with my original question on the pre-cats for an 2003
I gutted my pre-cats several years ago. No smell at all. I would go ahead and do it & not worry about any terrible smell. Just be sure to remove all of the pre-cat material before you reinstall the pipe. I cannot stress how important this is. After you do this, you will notice a more aggressive exhaust note and you shouldn't notice any bad smell. Hope this helps.
ExploreCCA Corvette Parts
Premium Supporting Vendor
close
- Member SinceOct 2004
- LocationManassas Park VA
- Veteran Field #3St. Jude Donor '07-'08,-'13-'14, '16-'17
Liked:438 Times in 336 Posts
Search and ye shall be rewarded...
Here you go.
http://forums.corvetteforum.com/show...utting+precats
Peace
Willfulone
Here you go.
Peace
Willfulone
Mike Mercury
close
- Member SinceApr 2001
- LocationS.W. Ohio. . . . . . NRA Life Member
Liked:180 Times in 112 Posts
there are no smell issues with gutting the pre-cats.
