[Z06] Mechanical and physical difference?
Old Nov 2, 2004 | 07:35 PM
paceace's Avatar
paceace
Default Mechanical and physical difference?
As I am new to Corvettes, could someone please either post here the differences or a link to a site that lists the differences between a standard C5 and a Z06? Thanks in advance. :o
Old Nov 3, 2004 | 09:52 AM
GOOSE JR.'s Avatar
GOOSE JR.
The "Corvette Black Book" is a guide to all corvettes but as far as some of the main differences is the motor in Z06 is the LS6 instead of LS1. HP is 385 in a 2001 Z and 405 in 2001, 2002 versus 350 in the standard corvette. The Z only came with a 6 speed while the auto and 6speed is available in the standard. The Zhas bigger tires and wheels, a more performance oriented suspension more agressive gearing in the 6 speed, the Z is lighter and since 2001 is the only hardtop, with no Z convertibles.
This is just a few of the differences, they are all C5's the Z is another version from the "General'.
Old Nov 3, 2004 | 10:41 AM
mryaknow's Avatar
mryaknow
Check out this link for the differences:
http://www.idavette.net/hib/ls6/index.htm
Old Nov 3, 2004 | 10:45 AM
SimonStern's Avatar
SimonStern
No power antenna
No telescoping steering wheel available.
No run-flat tires, but tires are 1" wider on all 4 corners.
No power passenger seat
Thinner windsheild and rear glass for weight savings.
Different wheels than stock (10-spoke wheels)
More aggressive brakes
Different Clutch
Different brakes (red powder coated)
Red fuel rail covers
Functional rear brake ducts
More aggressive gearing and only available in manual transmission
More aggressive suspension, with no selective ride control available.
- Larger sway bars
- Different shock vavling
- Stiffer springs
No fog lights, mesh covered air intakes to help feed the engine compartment in the same location as the fog lights.
LS6 motor, 385HP in 2001 and 405 from 2002-04.
- Stiffer valve springs
- Sodium filled valve stems
- More aggressive cam shaft
- 6500 RPM redline instead of 6000
Titanium exhaust system
Power steering fluid cooler
Only available in Fixed Roof Coupe
Includes standard heads-up display
Z06 Badging on fender
Z06 specific seats (with Z06 logo embroidered on them)
Z06 specific guage cluster with checkered pattern behind tach and speedo and Z06 logo
This is the bulk of it, off the top of my head.
Old Nov 3, 2004 | 11:46 AM
xilr8n's Avatar
xilr8n
http://www.corvetteactioncenter.com/...z06/index.html
Old Nov 3, 2004 | 02:53 PM
1983JZR3W's Avatar
1983JZR3W
Very good listing, very informative!!
Old Nov 3, 2004 | 02:58 PM
LuS1fer's Avatar
LuS1fer
But no HUD in 2001 Z06's. It was standard on 2002 and onwards by popular demand.
Old Nov 3, 2004 | 03:00 PM
barondw's Avatar
barondw
[QUOTE=GOOSE JR.]The "Corvette Black Book" is a guide to all corvettes "
If you are in to Corvettes you need to acquire the Black Book. Available through the museum, Barnes & Noble, etc. A new edition is published each year. Provides all the trivial stuff you want to know and more.
You can get a year by year description of the differences. Buy it.
Old Nov 3, 2004 | 10:56 PM
paceace's Avatar
paceace
You guys are great. I am new to Corvettes, and will get the book tomorrow. Thanks for the answers!
To Mechanical and physical difference?
