engine temp
Old Nov 3, 2004 | 10:20 AM
plumber's Avatar
plumber
6th Gear
Default engine temp
Do corvettes normally run hotter? I have a 98,it normally runs 190-210 but if I race around a little bit or get stuck in a lot of traffic it climbs on up there. Any way to drop temp or make it run cooler without changing the radiator? thanks
Old Nov 3, 2004 | 10:36 AM
vettenovice's Avatar
vettenovice
I have a 2001. In traffic (even in 50 degree weather), it goes up to 226. On the open road, it runs about 200 degrees. I don't really worry too much since the low speed fan kicks on at 226 and stays on until the temp goes down to 219. I can literally watch this happen on the DIC coolant readout. I can see the temp hit 226 and it almost immediately starts to drop when the fan starts up. My thinking is as long as the fan is working, it won't overheat.
From what I've read, most guys run cooler than us. So I guess ours are runnig a little hot but nothing to worry about. Vettes are designed to run between 200 and 230. If you want to, you can change out your themostat and have your fan reprogrammed to come on at a lower temp.
Old Nov 3, 2004 | 10:47 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
also... climb under the car and see if you have leaves and other debris blocking the radiator. It is a pretty common problem
Old Nov 3, 2004 | 10:50 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
yeap. Even in the 50 degree weather here and cooler air, if I am in stop and go traffic, it climbs up to 225..this summer every once in a while it would climb to 230. I keep an eye on the radiator to make sure nothing is stuck under there.
Old Nov 3, 2004 | 10:52 AM
bsmith's Avatar
bsmith
the problem area is way up high
check this out
http://forums.corvetteforum.com/showthread.php?t=938518
Old Nov 3, 2004 | 12:47 PM
The temps you mention are really about normal. Mine does the same thing.
Old Nov 3, 2004 | 12:58 PM
ersatz928's Avatar
ersatz928
Goto the "OTHER" tab at the top of the forum, then click Tech Tips, C5, and select the "C5 Fan Controller" article.
GranBichus's Avatar
GranBichus
Your temps look quite normal. IMO
Old Nov 4, 2004 | 05:42 AM
Patman's Avatar
Patman
With the stock fan settings I would see 220-230F coolant temps in traffic, but when I got mine dyno tuned I had them lower the fan settings, so now I never see over 194. It keeps my oil and trans temps much lower too, which is nice. I've still got the stock thermostat.
To engine temp
