AC keeps coming on !!!
Old Nov 3, 2004 | 10:47 AM
dbros9's Avatar
dbros9
Default AC keeps coming on !!!
All of a sudden my AC comes on with out notice. I will be driving along( it's 50 degrees here) and the AC will just come on. I turn it off and a few minute's later it come back on. I don't have auto turned on. Any thoughts on what this could be ???
Old Nov 3, 2004 | 10:55 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
If you are using the defrost setting, the AC will automatically be turned on to remove moisture from the air. You cannot turn the AC when using the defrost.
Old Nov 3, 2004 | 12:09 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Above is correct ... as long as you have the temp set where you want it ... don't worry about the a / c light being on. It is simply indicating the compressor being on and removing moisture.
Old Nov 3, 2004 | 12:31 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
once again, Zilla is on the ball
if it really bothers you, you can hit the "mode" button until defrost is off and then the ac isnt running
Old Nov 3, 2004 | 03:23 PM
dbros9's Avatar
dbros9
Default defrost in not on
no the defrost is not on - the AC just keeps coming on when it wants to when heat is on. Only floor mode is activated..
any other thoughts ??
Old Nov 3, 2004 | 03:55 PM
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
the hvac is using the a/c mode to remove moisture from the air. you have to use a manual mode to prevent this from happening automatically. just my .02.
Old Nov 3, 2004 | 04:26 PM
JC in XTC5's Avatar
JC in XTC5
The manual explains how to put the unit in full manual mode. You basically have to set the temp to either extreme hot or extreme cold to stay in manual mode, otherwise it will reactivate it's auto mode (i.e. AC) after about 10 minutes.
Old Nov 3, 2004 | 06:27 PM
Tombone's Avatar
Tombone
Reset your memory button on the drivers door after you turn off the AC.
Old Nov 3, 2004 | 06:37 PM
JimAgain's Avatar
JimAgain
Old Nov 3, 2004 | 07:07 PM
Zilla's Avatar
Zilla
Resetting the memory button has nothing to do with the issue at hand. The memory button is only when you first get into the car it will rememeber your setting or when you push the button on you fob. He said in his post that he turns it off then 10 minute later while driving the AC is on again. It's the Climate control at work
Old Nov 3, 2004 | 07:22 PM
JimAgain's Avatar
JimAgain
Memory definitely affects climate control but I agree it may have nothing to do with his problem. In fact, there may not be a problem.
Some in this thread suggests that it always happens:http://forums.corvetteforum.com/showthread.php?t=565615
He may need to check his key fobs or just reset it out of auto mode.
Others' thoughts:http://forums.corvetteforum.com/showthread.php?t=896831
I wouldn't be surprised if it were an automatic feature intended to dry the cabin air below a certain ambient temp.
To AC keeps coming on !!!
