I use the glass top almost exclusively. We store the white top in a padded storage bag that we bought from C5 Creations. It works great and has handle so we can hang it from a nail on the wall in our garage. Very strong and safe.
C5 Creations
They also make a great padded storage bag that attaches inside the trunk so when we take off the glass top it is stored and protected in this other bag.
in someone elses garage.
I dont like the clear tops on torch red..........so i ditched mine to a member of the flying roof club.
i had no use for it and it would never have been used
I bought two pieces of galvanized pipe and two plates that the pipe screws into. The plates have four holes on them and I lined up two each on studs in the garage and screwed it to the wall. Then, I took pipe insulation and wrapped it around the pipe. I wrap the top in a sheet and rest it upside down on the pipe. It takes up virtually no room on the wall and is easy to get to.
I made a wall bracket from parts at Home Depot.
Two shelf brackets, two leg inserts and a set of fastening straps.
Send your email address and I'll send pics if you want.
There's also a ready made bracket available from Ecklers but I have not seen or used it - only saw it here.
