Oil pan drain plug
Old Nov 6, 2004 | 02:04 AM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Default Oil pan drain plug
What do you suppose the engineer was thinking when he decided to put the oil pan drain plug in the front of the pan.....and then made it so it's nearly impossible to get a socket on it?
Was this guy having the male equivilent of a "bad hair day" then, or what?
Old Nov 6, 2004 | 06:35 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I see, changing your oil recently weren't you? It's amazing how great the design of an individual component seems....right up until you assemble it with some of the other components (with great designs too of course) and then you go...Oh S***!
Paul
Old Nov 6, 2004 | 06:57 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Well ... how 'bout another mod? Move the drain to the bottom rear of the oil pan so it can be drained while the front is on ramps. Might be doable, and reasonably simple.
Old Nov 6, 2004 | 08:19 AM
TOOGECKO's Avatar
TOOGECKO
This is what I think the Germans are so good about. Look at the components in a BMW or Mercedes. They usually appear to be well thought out. They are firm believers in "concurrent" engineering, the design of components and systems as they relate to the whole...
Old Nov 6, 2004 | 10:52 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
What makes you think the design engineer was male?
Old Nov 6, 2004 | 12:13 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I've never been able to get a socket on it. I use a 15mm wrench... and since I'm normally looking at it backwards, I have to think very carefully about which way to turn it.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 6, 2004 | 03:05 PM
ErnieN85's Avatar
ErnieN85
screw in the plug. Then put a 15mm socket on the plug,insert a short extension then a 3/8 torque wrench. it does work!
Old Nov 6, 2004 | 07:20 PM
C66 Racing's Avatar
C66 Racing
Never tried that. I bought myself a set of ratching wrenches instead.
Course you have to be careful with those as well... set them for tighten but then put it on backwards which is the easier angle for the oil pan bolt and then it ratches the wrong way.
Old Nov 6, 2004 | 10:14 PM
ZX-11's Avatar
ZX-11
Default Know what you mean.
I remember having a few choice words for GM the first time I did an oil change - I couldn't believe they put the drain plug somewhere where you couln't get a socket on it. Put a wrench on it and the bolt was really on there good. Put some pressure on the wrench and the bolt finally broke loose. Of course I cut my fingers up pretty good when my hand slammed into one of the really sharp crossmembers. Yeah, I was not a big fan of GM at that moment in time.
Old Nov 7, 2004 | 12:58 AM
MagikDraggin
Cruise-In V Veteran
Well, if it wasn't, then it certainly had to have been a blonde.
I just know, I'm probably gonna catch it for that one.
Has anyone successfully attempted to drill and tap a hole in the rear of the pan?
Old Nov 7, 2004 | 02:49 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
BWAHAHAHAHAHAHA! Yeah! Right!
Old Nov 7, 2004 | 02:50 AM
JACKAL0PE's Avatar
JACKAL0PE
Now THERE'S a point!
Old Nov 7, 2004 | 02:51 AM
JACKAL0PE's Avatar
JACKAL0PE
Have you lost your mind?
Old Nov 7, 2004 | 04:09 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I bought one of those little valve deals where you install it once and from then on just flip it open...drains a little slower but its damn easy to change the oil
Old Nov 7, 2004 | 07:52 AM
Tom/99's Avatar
Tom/99
Old Nov 7, 2004 | 08:09 AM
blktie8's Avatar
blktie8
All I can say its easy and this is a great car...........
Old Nov 7, 2004 | 08:36 AM
Golf Man's Avatar
Golf Man
It probably was not engineering, but economics.
I'd be curious how many people now take their
vettes to the dealer to have the oil changed,
at 60 plus USC.
To Oil pan drain plug
Old Nov 7, 2004 | 08:45 AM
VetteDrmr's Avatar
VetteDrmr
Here's a hint for loosening those bolts that are a bit, er um, "tight". Use the correct size box-end wrench, and then use a "soft" hammer (I use a 2 lb. generic orange dead-blow hammer) to loosen it. Takes much less effort and therefore more control when it does break loose.
HTH, and have a good one,
Mike
Old Nov 7, 2004 | 09:46 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
The engineer had just finished designing the steering column lock before doing the oil drain plug location.
Old Nov 7, 2004 | 10:32 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I think that used to be true, but not so much anymore.
If you look at the other car forums, there are lots of complaints about percieved cheapness and crazy ergonomics (until you get into something like a Mercedes SL or AMG). BMW seems intent on alienating their (formerly) loyal performance-oriented owner/drivers. When it came time to replace my 5-Series in 2004, I found that they had eliminated the M-coupe and M5, and were shoving the infernal iDrive down consumer's throats of the remaining models (except the 3-Series, which I wasn't interested in). That's why I'm driving a C5 now.
