What can I use to paint the rotor hub/hat?
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
I just picked up a new set of NAPA rotors and I had a great idea: I wonder if I could paint the hat area to keep them from rusting? I'd probably do the outer edge of the rotor as well...
I doubt the normal "rustoleum" stuff would survive the high temps. Anybody have any other suggestions? Maybe the hi-temp stuff they use on BBQ's?
You have a nice looking vert and IMO, you should have paid a little extra for the zinc plated, drilled and slotted Brembo sport brakes. Less than $300 and they never rust and look so much better than the stock rotors. Can you still return them?
St. Jude Donor '05
Originally Posted by Umrswimr
Thank you for the kinda words. However, drilled/slotted rotors are not allowed in the SCCA ASP class. Rotors must be stock or stock replacements...
St. Jude Donor '05
The NAPA rotors are $25 each. I believe stockers are ~$40 each plus shipping from Fichtner.
Most of the hardcore racers (I do not qualify for that title) just buy the NAPA rotors in mass quantity because: a) they're cheap B) they're better performing than more expensive slotted/drilled rotors and C) they're basically a consumable item on a racetrack.
At any rate: I was not aware that the stock rotors had painted hats. Mine look like dark rust.
FYI: Here is a list of allowed modifications for Street prepaired. Anything not explicitly listed as an allowed modification is prohibited. Brake rotors are not a allowed modification:
http://www.moutons.org/sccasolo/Rules/sp.html#s14
However, there are MANY people who run aftermarket rotors in Street Prepaired and only at the national level will anyone say anything. I've personally seen DOZENS of cars violate that rule. I wouldn't worry about it.
Received 19,859 Likes
'20-'21-'22-'23-'24
High heat engine paint would work. Or, you can always go to something like Folia Tec - I have it on my calipers and it has held up very well in the three years it has been on the calipers.
I used the Rust-Oleum High Heat paint in Bar-B-Q Black. The Bar-B-Q Black comes in both brush on and spray cans. I found 8-oz cans of the brush on at Wal-mart. It has held up very well for me but I don't track mine very often.
Rust-Oleum High Heat Paint
Painted my calipers and hats with Rustoleum over a year ago, they still look great. DISCLAIMER: My car only sees street use under normal driving conditions. Not sure how they would hold up on the track
You might also check with local metal shops - platers in your area. I put drilled/slotted GM perf parts rotors on the front, but got them white cad plated (similar to zinc) for ~ $50 for the two. The plating on the brake contact area wears off shortly, but the rest looks great for almost forever (mine still look great after > 50K miles and couple of years). Paint also works - just ensure your get the high temp type.
not worth it, unless they are an oversized set up
i got mine from Oreilys, cost about $12 more each, but they come with a lifetime warranty. if they warp, no loss
oh BTW, i used hightemp grill flat black paint on the backside and the center vents on my new rotors. i hope it keeps the rust down. brake dust is one thing, but i can do without the rust spewing out onto my chrome wheels
i race this coming weekend, so i will see how well the paint holds up
I just did my calipers with the 1200 degree high heat stuff
Rustoleum on the calipers and body color (body shop color match) on the rotors. No special high temp or anything, no problems.
Bob
Bob
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Originally Posted by Tigger
I used black grill paint. Picked up a small can at Wal-mart. Brushes on very easily, and holds up well.
I have the NAPA rotors. I used flat black grill paint. I used the spay can. Looks stock.
