Question about fluid capacities....
Old Nov 7, 2004 | 02:57 PM
Laguna Blu's Avatar
Laguna Blu
Default Question about fluid capacities....
I'm ordering oil, tranny fluid and gear oil and I know that the oil change requires 7 quarts. My question is do I need 5 or 6 quarts of tranny fluid for a standard change on an A4 and for the rear is 2 quarts enough? I already ordered the limited slip additive, tranny filter kit and oil filter.
Old Nov 7, 2004 | 04:10 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
2 qts for the rear, 4 for the tranns. ( you will only use approx 3½ for the tranns)
Old Nov 7, 2004 | 05:58 PM
Laguna Blu's Avatar
Laguna Blu
I thought I once read 5 or 6 quarts for the tranny fluid refill. Are you sure that 4 quarts will be enough?
Old Nov 7, 2004 | 07:54 PM
Here's what the owners manual states:
Automatic Transmission (Drain and Refill): 5 quarts
Rear Axle: Lubricant - 1.69 quarts
Limited Slip Additive - 4 ounces
Crankcase: 6.5 quarts, but you will of course have to buy 7.
Old Nov 7, 2004 | 11:52 PM
Laguna Blu's Avatar
Laguna Blu
Thanks. Guess I should have just checked the owners manual huh? I usually go to the forum first.
To Question about fluid capacities....
