need exhaust help please!
Old Nov 7, 2004 | 05:21 PM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
Default need exhaust help please!
I have Supermaxx headers on w/ a corsa indy pace car catback...after installing the headers my car is too dang loud, especially when it runs fr the first 5 minutes while its in its loop phase (Run Rich)....what can i do to make it quieter w/o removing the headers? Would there be a better cat back?
Old Nov 7, 2004 | 05:39 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
I'd be looking for some Z06 Ti's if I were you. Failing that, I'd go down to Corsa touring.
Old Nov 7, 2004 | 06:46 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
Turn The Radio Up :d
Old Nov 7, 2004 | 07:27 PM
~SPEEDY~'s Avatar
~SPEEDY~
Old Nov 7, 2004 | 07:41 PM
You could get some Corsa Touring, B&B Route 66 or similar "quiet" aftermarket exhaust to run on the car. Sure wouldn't want to take off the headers.
Old Nov 7, 2004 | 08:53 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Seems this is a common problem with people that add headers. By the time they add headers with one of the louder aftermarket exhausts, it's just too loud. (or they're just too old...lol)
Eventually I will add headers but at that point, I'm sure I'll be looking for a set of Ti exhausts.....
Mark
Old Nov 8, 2004 | 10:57 AM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
will the corsa touring really make much of a difference?
Old Nov 8, 2004 | 12:18 PM
JACKAL0PE's Avatar
JACKAL0PE
Corsa Touring is supposed to be almost a stock replacement with just a bit more kick WOT. If it WON'T make that much difference, the only thing left is to put your stock system back on (or the above mentioned stock Z06 system). There isn't anything else quieter.
Old Nov 8, 2004 | 12:39 PM
JimAgain's Avatar
JimAgain
Flame suit on.
I hear many recommending Ti's. I doubt if you would have gone with the Corsa indy's if you could stand the sound or restriction of the Ti's. I hear at least as many Z06 owners complain about the Ti's as I hear non-Z06 owners praising them. But then, that's why so many of the Ti's become available for non-Z06 owners. FWIW I did try Ti's briefly but also found them too quiet for my taste.
As for your question, I have noticed the same thing with my LT's and Borla Stinger combo on initial startup, but it's really only for less than 1 minute. That's when the garage door opens.
Good luck
Old Nov 9, 2004 | 12:37 AM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
is there anyone in particular that has the best price on the corsa touring catback?
Old Nov 9, 2004 | 05:30 AM
LBear's Avatar
LBear
Headers will make ANY exhaust system louder! Combine that with aftermarket mufflers and the tone will get louder. Stock mufflers will quiet a header car down with MAYBE a 5-10HP loss.
Old Nov 9, 2004 | 10:04 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
The Corsa Touring is not a complete catback (no X-pipe).
As for price, WCC is competitive. If you like the look of two big ovals, they also have an exclusive version:
http://www.westcoastcorvette.com/sho...ail.cfm?id=439
Old Nov 9, 2004 | 10:06 AM
sharpvet03's Avatar
sharpvet03
An X-pipe might calm it down a little-but it won't be much
Old Nov 9, 2004 | 10:09 AM
EHS's Avatar
EHS
I would try an X-pipe first, and then if that's still too loud, the Corsa Touring.
Or, if you still have the stock exhaust, why not "test" that first.
Old Nov 9, 2004 | 12:36 PM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
why would i need an x pipe if my supermaxx headers allready have one?
Old Nov 9, 2004 | 01:17 PM
KKu77's Avatar
KKu77
I had Corsa Indy's with headers before changing cams. After the cam install, it was way too loud. Went to the tourings and it's a day and night difference. I was able to find someone locally who was willing to swap exhausts. I'm sure you'll be able to find takers for your Indy's
Old Nov 9, 2004 | 07:49 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
You don't. I don't hear much about Supermaxx, and guessed (incorrectly) that they were shorties.
To need exhaust help please!
