3. Automatized car wash with pressurized water ("laser wash")
I personally exclude No. 1 as: i) it may easily generate small scratches when not done carefully; ii) it is time consuming; and iii) therefore expensive when paid for. The "soft brushes" types are nowadays made from man-made and soft leather-like material and I like the result. I have no experience yet with No. 3, but as my Coupe's roof sealings are far from perfect, I fear that water will come inside the car.
Anyway, with Nos. 2 and 3, on the devices I found, one needs to select some coating of the car in order to get the car dried. On the other hand, leaving the car wash with a wet car easily give rise to spots, which, of course, I want to avoid. On the other hand, I do not want to have some dubious coating put on my clear top and on the large glass surfaces.
Here's everything you've ever wanted to know and some things you don't, about taking care of your car. (#1, done properly is the ONLY way to wash a corvette.... )
Several very knowlegeable people hang out in the Car Care Products section of the Forum and they should be able to offer you some very good advice. Good luck.
I got that Mr Clean auto dry from my kids I put Zaino car wash into it came out very nice I only had to hand rub a couple of spots. Pretty good for an after drive clean up. But if I am going to do a full wash I hand wash with new sponges I found a place on the web that sold flattened sponges and I use them once and throw them away
Since my Z is garaged most of the time, it does not get as dirty as my other vehicles.
I only bucket wash when it is necessary, like after a road trip or when there are tons of bugs on the front etc.
When I bucket wash, I use warm water (I have soft, hot water in the garage) and I use a sheepskin mitt on everything above the bottom of the door panels, and a cotton covered wash sponge on everything below the door panels.
To dry it, I use either 100% cotton towels, or 100mph blow dry... did I say that?
I use the self serve car wash here in town. It has nice water pressure and a spot free rinse that really does work. I can get up in the wheel wells and under the car with the wand. Not had any scratches to the paint (at least none that I can tell).
I do it by hand ... doesn't take long. Drying takes longer than washing, to get the door jambs, hatch opening, and hood dry. I've tried the leaf blower method and that works well, but it's a lot of trouble to get it out. I use a squeegee instead, followed by a towel.
The outside faucet that I use is also on my water softener, so that works out well for a spot-free car.
