New Column "not" lock troubles
Old Nov 8, 2004 | 11:40 AM
Torchy2000's Avatar
Torchy2000
Default New Column "not" lock troubles HELP!
Well, I'm getting gas yesterday morning, just had the column lock recall done several weeks ago, and I get in after fueling, and all the electronics come on, but no starter.
I pull the key and the column lock is not engaged. I can steer it. Has anybody had this problem?? Is there anything I can do to engage the column lock so the car will start?? HELP!
The embarrassing part was I was just bragging on how trouble free the car has been to the clerk who was admiring it
Old Nov 8, 2004 | 11:41 AM
jjjflex's Avatar
jjjflex
That Sucks BigTime.....
Old Nov 8, 2004 | 12:12 PM
JC in XTC5's Avatar
JC in XTC5
Sounds like the Pass-Key system. Since you have an A4, the only 2 things I could think of are the transmission wasn't in P or N, or the Pass-Key system did not read the key pellet properly.
If you have a 2nd key, try that, or even better use some alcohol and Qtip and clean the ignition keyhole - the contacts may be dirty.
Old Nov 8, 2004 | 12:26 PM
Torchy2000's Avatar
Torchy2000
Yeah man! didn't even think of that...
Thanks!
Old Nov 8, 2004 | 01:00 PM
Hope you get it solved. These things always seem to happen at the most inopportune time.
Old Nov 8, 2004 | 01:37 PM
roscoe118's Avatar
roscoe118
Does it have an AGM battery in it? Whem mine died last month ('02 coupe), it died just like that - NOTHING, NADA, ZILCH. It took a 10 minute jump with my wifes cars just to get it to turn over and limp home.
Good Luck,
Old Nov 8, 2004 | 01:42 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Torchy, is it still sitting at the gas station?
Old Nov 8, 2004 | 02:08 PM
Torchy2000's Avatar
Torchy2000
... yeah it is, but it's safe. I know the owners there. I'll have it towed (flat bedded) to the dealer tonight if the spare key thing doesn't work
Old Nov 8, 2004 | 02:10 PM
Torchy2000's Avatar
Torchy2000
... and it has a brand new (1 week old) battery in it!!
Old Nov 8, 2004 | 02:17 PM
bagwell's Avatar
bagwell
that doesn't mean anything....could be defective
Old Nov 8, 2004 | 02:20 PM
Torchy2000's Avatar
Torchy2000
yeah, true dat. However when I turn the key on, everything kicks on, It appears to have plenty of juice, till I go to the next notch to engage the stater and the electrical kicks off....
Old Nov 8, 2004 | 07:15 PM
bagwell's Avatar
bagwell
assuming A4? tug/wiggle the shifter fwd & back while attempting to start
To New Column "not" lock troubles
