Headlight bulb changing??
Old Nov 8, 2004 | 11:39 PM
bsmall423's Avatar
bsmall423
Default Headlight bulb changing??
I need to replace the headlight bulb, any links to a picture walkthrough? Im changing out the foglights while im at it too... any help would be much appeciated!
Old Nov 9, 2004 | 12:21 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
This is about changing headlights to HIDs, but the procedure for changing the bulbs is the same. Hope it helps! http://forums.corvetteforum.com/showthread.php?t=872743
Old Nov 9, 2004 | 01:46 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Changing the headlight bulbs is very easy. Remove the plastic housing around the light the stick your hand behind the headlight and turn the bulb and its out. Replace the bulb them put it back in the opening then turn.
Old Nov 9, 2004 | 04:23 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Just make sure you seat them correctly it is very easy to bend the little tabs also if you use halogen bulbs not to touch the glass....
Old Nov 9, 2004 | 10:58 AM
majbillgsd's Avatar
majbillgsd
Default changing headlights
when changing out to REvextremes or other HID lights, are they white and bright when they are beaming on the road? I noticed they are bluelike when you look at the car withthe lights on but didn't know about the way they shine on the road if white or not.
Bill
To Headlight bulb changing??
