Mysterious Traction control
Old Nov 9, 2004 | 08:52 PM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
Default Mysterious Traction control
I have a 99 FRC. Sometimes When I driving the T/C will come on and the Dick will say" traction control active" The car will not accelerate until I disengage the T/C by pushing the button. This occurs when I am going straight and in turns. The car is not holding any codes after it does it. So, I have to have a tuner ride in the car and hope it does it while it plugged into the diagnostic computer. We are thinking; yaw sensor, wheel sensor or electrical harness problem. Has anybody had this problem?
Old Nov 9, 2004 | 10:14 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Old Nov 9, 2004 | 10:17 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
A couple things....
1. Spinning a wheel either during acceleration or cornering can turn it on.
2. Your car is so low you pizzed off your computer!!!
Old Nov 9, 2004 | 10:20 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
3. His tire sizes are wrong.
Old Nov 10, 2004 | 01:15 AM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
Wrong? please ellaborate? what does pop mean? ????????
Old Nov 10, 2004 | 01:23 AM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
Ok I just went and checked 275/35/zr18 Kumho exctsa supra's all the way around. How do I fix? I have to get back to 17 in front or?
Old Nov 10, 2004 | 01:30 AM
vetterlatethannever's Avatar
vetterlatethannever
It's cause you're running supra tires on a Vette!! LOL!
Sorry, I have no real answers except that POP means "lurking" or waiting on an answer because they are curious too.
Old Nov 10, 2004 | 01:34 AM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
WHA? I was advised that the supras wre great for auto x and street racing. I have raced with them and they hold up fine. Or maybe you were implying rice supra?
Old Nov 10, 2004 | 02:04 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
Ok, well, i had a similar problem as well, however i think i may have been getting a code, i don't remember exactly....Have you had your Steering shaft disconected lately?
Old Nov 10, 2004 | 02:35 AM
Grand Slam's Avatar
Grand Slam
If you're running 18's all around the front wheels will be turning at a somewhat lesser rotational speed than what would be normal with 17 inch tires. That means your computer will sense that your rears will be turning slightly faster in comparison to the fronts than is normal. I suppose it is possible your traction control is sensing this as wheel slip. Perhaps someone with more technical knowledge than I have can confirm or debunk this theory.
Also, it is a DIC, not a Dick. ;-)
Old Nov 10, 2004 | 07:30 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
That does make a lot of sense, but there are a lot of folks with larger than stock wheels out there.
I wonder if that feature can be reprogrammed?
Old Nov 10, 2004 | 08:16 AM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
You need to buy two tires of a different size.
Old Nov 10, 2004 | 09:31 AM
Wah's Avatar
Wah
ECSTA MX is a good tire, ECSTA Supra 712 is junk.
Try putting more air in the fronts. That's weird that you got that error, I have ran same size tires/wheels all around and I never got any error, even with the bald ones in the back.
Old Nov 10, 2004 | 09:37 AM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
There are a number of people running 18's all the way around. The combination of width*aspect ratio gives you the desired difference in the true tire diameter that is needed for the system to work correctly. Someone will chime in with their aspect ratios front and rear...
Old Nov 10, 2004 | 09:42 AM
steeleaway's Avatar
steeleaway
My Traction control is always on but I had noticed that on a few roads around here where there was extensive construction when the elevation of the road would drop from a higher level to a lower level, say 3/4" to 1" at 45 mph, I would get the same message. I think it is because it is doing its job??? The tires lose the traction of the road for that split second and it engages and tells you that it is engaging. Just my theory????
Old Nov 10, 2004 | 09:46 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Shhhhhhh. Don't tell him that!!! I've got Ecsta MXs all around and I run against this guy in autocross events. (He smoked almost everybody last time out except some blown Z06s - but I think he's cammed up with some other goodies under his hood we don't know about.)
Old Nov 10, 2004 | 10:11 AM
Stangkiller
Although personally i don't believe it's tire ratio's he is running too small of a rear tire, if he goes up to a 315 35 18 that'll raise his rear tire to a larger diamater, and fix his ratio problems....However he's been running this way for a while now!?
Hey Cajun, assuming i get my car fixed <exhaust problems> Matt and I are talking about going racing tonight, u should take a cruise down here, we'll find out exactly what his car has!
To Mysterious Traction control
Old Nov 10, 2004 | 10:41 AM
robvuk's Avatar
robvuk
18" wheels all the way around is fine. But you have to have the 1" stagger from front to rear. Go with a larger size in the rear or a lower profile in the front. In your case you have 275/35's, a 30 series in front or a 295 in the rear should solve the problem. Pretty much just as 99C5alan said.
Old Nov 10, 2004 | 10:57 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I would but I've got my car in pieces parts right now. I took my K&N filter off and it's such a PITA to do I'm modifying it so it can be removed and cleaned easily.
I've got a Veteran's Day Parade tomorrow, too, so I'll be cleaning it up for that later.
But........ I've got the Evolution High Performance Driving School this weekend. Now THAT is gonna be a lot of fun!!!
Old Nov 10, 2004 | 12:43 PM
VetteMan4Life's Avatar
VetteMan4Life
That cant be right, I am running 19s up front with 20s out back and I dont have any problems at all. I read somewhere that as long as you stay within a certain size from your stock size you will be fine.
