Headlamp Doors
Old Nov 10, 2004 | 10:47 AM
JTAllen79's Avatar
JTAllen79
Default Headlamp Doors
Can anyone tell me how to align the headlight doors? The left one goes down flush but the right one sticks up about 1/16". Also after washing it the other day they were making a gawd awfull "skweeeeeek" that went away after a couple days.What is a good lubricant that won't gum things up? Thanks...JA
Old Nov 10, 2004 | 01:07 PM
GranBichus's Avatar
GranBichus
It could be something is stuck inside the headlight thats not letting the door close all the way, but chances are the plastic gears of the headamp motor might have some teeth missing.
Mine makes the "skweeeeeek" noise all the time when is cold outside, it made it even when it was new.
Old Nov 10, 2004 | 02:37 PM
SilverRoadster00's Avatar
SilverRoadster00
I have a similar situation. My drivers side goes all the way down, then pops back up about the same as you described. It seems like the stop may be a bit off. For now, I just pop the hood and manually adjust it to being flush.
Old Nov 10, 2004 | 06:41 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
There are four aligment screw under each cover, one under each corner. They are mounted vertically with a white plastic tops. I have the same issue, but after trying to align the cover, I found out the whole headlight aseembly is mounted to the car ... crooked! As for lube, use grease ... WD-40 attracts dust and gunk. Hope this helps
Old Nov 10, 2004 | 07:00 PM
jimbee's Avatar
jimbee
Yeah, just the four adjustment screws, use a T-15 to remove the headlight cover and adjust up or down. Also check the control arm for play, from the motor to lamp assm., sometimes these get worn.
Old Nov 10, 2004 | 10:03 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
loosen the 4 and align
To Headlamp Doors
