compare
Old Nov 10, 2004 | 11:53 PM
vettest's Avatar
vettest
4th Gear
Default compare
HI guys... just a quick question.
Can any body explain to me what the different between the normal c5 and the zo6?
Old Nov 11, 2004 | 06:07 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Here are some places you can start to read up on the differences.
Basically, exterior based on the Fixed roof coupe, different wheels, more HP/Tq, rear brake cooling ducts, transmission cooler
http://www.corvetteactioncenter.com/...z06/index.html
http://www.idavette.net/facts/2002/index.htm
Paul
2002 Z06
1997 Coupe
Old Nov 11, 2004 | 07:02 AM
LuS1fer's Avatar
LuS1fer
Fixed roof only on Z06 making it 12% stiffer and in conjunction with the FE4 suspension unique to the Z06, far better handling than a regular C5. More power - 385 in 2001 and 405 thereafter.
02 Z06 onwards has a more aggressive cam and sodium filled valves. 02 Z06 onwards has HUD as standard but the 01 Z06 never had the HUD. Z06 is lighter than the C5 as well.
Old Nov 11, 2004 | 09:50 AM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Old Nov 11, 2004 | 10:03 AM
sharpvet03's Avatar
sharpvet03
That pretty much sums it up,except for the apperance(rear brake cooler,rear window,rims and tires(no run flats) and a few other things)
To compare
