[Z06] CAGS Elim. Install question
Old Nov 11, 2004 | 12:00 PM
DaveJP's Avatar
DaveJP
Default CAGS Elim. Install question
Is it absolutely necessary to disconnect the battery when performing this mod?
Thanks.
Old Nov 11, 2004 | 12:01 PM
skip89's Avatar
skip89
I never have, to install a cags in my Vetts....
Old Nov 11, 2004 | 01:01 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Thanks.
I did, as per the instructions. I think it's for safety reasons.
Old Nov 11, 2004 | 01:35 PM
l2vette's Avatar
l2vette
Same here, I did it on my 2000 and on the bad boy '04. No problem.
Old Nov 11, 2004 | 06:55 PM
RMBLROAR's Avatar
RMBLROAR
I didn't. Just raised it up, unplug the connector and installed the cags eliminator. No sparks, smoke, arcing or the like. Took all of about 2 minutes once it was up far enough to get under it.
Old Nov 11, 2004 | 07:04 PM
BR Duke's Avatar
BR Duke
What all will device do for you? Thanks for the help.
Old Nov 11, 2004 | 09:10 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
It will eliminate the pesky 1 to 4 forced shift.
Old Nov 11, 2004 | 11:46 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Thanks.
Probably not, but I am in the habit of disconnecting the battery anytime I do electrical work.
As mentioned, it eliminates the 1 to 4 skip shift, but also puts a resistor in the circuit so the PCM doesn't see a short and give a fault code. With this device, you will still see the skip shift light come on on the dash, but the electrical signal will just run through the resistor instead of the solenoid that activates the skip shift.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 12, 2004 | 03:22 PM
INFERNO Z07's Avatar
INFERNO Z07
If it were an active circuit I could see disconnecting. Not neccesary here. Unplug, plug and you're done.
Old Nov 12, 2004 | 05:29 PM
Scott04Z's Avatar
Scott04Z
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
I did not disconnect the battery and had no issues at all. The only sparks flying were a result of my joy at not having to worry about that stupid skip shift feature any more!
To CAGS Elim. Install question
