I built some ramps to drive up on because I lowered mine. Once up on the ramps I can jack up the front and raise the whole front up then place jack stands. Works great for changing oil as well.
What, no fiberglass? When I had a run in with a concrete light pole “OUCH” it sure looked like fiberglass. There was a big jagged hole in my R ¼ panel and it sure looked like fiberglass to me, even through the tears!
No fiberglass. The illustration below identifies the materials used in the C5 body panels.
No fiberglass. It might look like it, it's a fiber reinforced plastic basically, but it's not fiberglass. All of the strength, none of the weaknesses.
Jacking up a corner is fine, no need to open doors or anything. That's an old wives tale that comes from previous generation vettes. Besides, you really can't jack up a corner anyway. The frame's too stiff - it'll take the opposite end's wheel with it.
No, I just wanted to get a cheap jack and get it up high enough to pull one wheel at a time. Since it's a one time use, I don't want to spend a lot, but I don't want to damage the car either.
That won't work.
To do a good job, you're going to have to get to the back of the calipers, particularly the rear ones. That means laying down and getting under the car and that's NOT something you should do with just a jack.
Bite the bullet, put it on a jackstand and then just do one end of the car at a time.
Learned a trick about jacking a Vet from an old time GM mechanic. If you jack up just one corner at a time you should open the doors, the hood, the truck or the hatch. He said it lets the body flex without stress.
That was a suggested technique prior to C5, but the C5 is way stiffer than earlier models, so it's really not necessary. Jack away!
Good point, I really don't want to get my melon smashed painting the calipers. A squashed melon just aint worth it. Anyway, why paint the back side that you can't see?
The C3's and C4's were flimsy compared to the C5. If you can't jack up a car one wheel at a time, it's time for the crusher and a new car. You can prove this to yourself by jacking up the left front wheel, then open and close the drivers door. There shouldn't be a problem.
