[Z06] Comp. Ratio
Old Nov 13, 2004 | 09:17 AM
SWHITEZ's Avatar
SWHITEZ
Cruising
Default Comp. Ratio
I'm In The Middle Of The Rebuild On My 01z.
My First Question Is What Is The Highest Compression Ratio That You Can Run On Pump Gas. I Know That The Stock #10.5-1
Is Very Close To The Edge.
My Next Question Is If Any One Has Ever Used Diamond Pistons.
I Am Looking At The Dome Tops But I Think We Are Getting To Close To The Edge. There Dome Top Is A 11.5-1 Ratio Out Of The Box.
Old Nov 13, 2004 | 09:56 AM
GOOSE JR.'s Avatar
GOOSE JR.
I can't give you a complete answer but I am rsearching after market heads and it seems like they all bump the compression up to 11 to 11.25 depending on if you want to fly cut the pistons.
