Was having a great day until......I Picked up a 4" screw in my right rear Goodyear Runflat. Chevy dealer wouldn't patch it because it was "too near sidewall" and said I need 2 new rear tires. Since I have plugged many non RF's with screws like this over the years and since my rears only have 7500 miles on them I plugged it myself. At what mph will the tire be unsafe?
You are more likely to have somthing go wrong with another tire on your car that the one you plugged. For freeway speeds, you should be just fine. There is probably one chance in a million at 180 MPH that you would loose air out of that tire. There is a lot of rubber along that sidewall that regular tires don't have.
I picked my car up July 29th, and about 2 months ago we had the car up to put the Stingers on.
A friend of mine noticed something shiny in the right rear tire- a nail
So I started monitoring the tire pressures and noticed that tire was consistently about 5 lbs lower than then left rear, no matter how recently I filled it.
Took it back to the dealer to have em look @ it while they did the oil, and they found it had been plugged previously. They said the EMT tires shouldn't be plugged, but could be patched.
Well, they replaced the $350 tire FREE OF CHARGE since "it musta came off lease like that"
Based on my experience, I'd replace the tire. Or at least keep an eye on the pressures
Per your warranty book on the tires, the Goodyear EMTs can be repaired for a flat as long as the puncture is in the tread area. I was told that the acceptable method of repair is the plug and patch method. I had a flat in a rear tire and it was repaired using this method. Didn't have a single problem afterwards with it.
I've had one front tire handled both ways..........1st time was early miles and we patched from indside............next time was late in it's life and we plugged. As for safety....I'm not sure.........I've been to 171 with the patch and 160 with the plug so I can say MINE were ok to those speeds.
I sure wouldn't buy a new one UNLESS it's really close to the sidewall.
Was having a great day until......I Picked up a 4" screw in my right rear Goodyear Runflat. Chevy dealer wouldn't patch it because it was "too near sidewall" and said I need 2 new rear tires .
Why "two" new rear tires. Did you ask them if these punctures are "contagious" and spread to other tires? And if so, shouldn't you replace all "four" tires? Sound like a bunch of freakin' idiots trying to make a profit on two tires instead of one. Now if you had perhaps 20k or more miles on the rear tires two may have been a consideration but 7500?
Back to the original topic.......it usually is a wise decision to replace one of these EMT's if the hole is near the sidewall. Internal patches aren't known to hold very well in these locations. If you simply do in-town driving and short trips well plugging or patching may work out for you. But, if you go on long trips or you do the occasional 100MPH plus burst(you know because the accelerator gets stuck ) personally, I'd go on and replace it.
I plugged my right rear and put 20k on it and did up to 150 mph. No problem. Now I have GY D3's and love them. I carry a compressor plug kit and jack. One happy camper.
