Don't worry.... black is the easiest to match... most of the time you don't even need to blend black or white whe painting a new panel on a car. She'll be all better in no time.
WOW, That sucks dude
Question: What straps were being used and how were they hooked to you're car?
Brian....it was actually the D ring in a featherlite trailer that let loose.
After looking at everything I saw the strap was not broke at all. When we went to strap down another car the D ring was split in half.
Fethaerlite uses Aluminum D rings I guess for weight
That is terrible. I hope they wont have to blend the fender. You know, if you are selling it, you can just add more flame trails through the center to break it up if there are any slight differences.
Damn that sucks Jim. You are not going to bring it out here for the repairs are you???
No if it would have happened closer to Vegas I would of but it was almost home (25 miles) so I am going to do it myself.
Should not be a big deal just a pain in the @zz
Time to check double my setup
I know mine are steel but...can't be to careful.
Good luck with the repairs
