Stock fog lights
Old Nov 13, 2004 | 02:58 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Default Stock fog lights
Best I can tell, they're entirely decorative. I can turn them off at night, then turn them back on and can't tell the difference.
Is there a useful changeout that actually is effective? I've seen some posts about PIAAs ... but is the changeout simple (remember ... it took me all morning just to install my Blackwing ).
Old Nov 13, 2004 | 03:13 PM
pastorbrad's Avatar
pastorbrad
St. Jude 15 Year Donor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
IMHO, the PIAA changeout is not at all simple. The majority on CF would tend to differ. However, you can also get 50w bulbs to upgrade from the stock 35w - anyone else help us out on the bulb type? I know it's easily found and cheap at Autozone, etc.
Old Nov 13, 2004 | 03:19 PM
91LSMAN's Avatar
91LSMAN
I think the stock C5 fogs would look great with some PIAA ION YELLOW bulbs. They give a great contrast.
Old Nov 13, 2004 | 04:15 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Aim them, it makes a world of difference, I did and it works, really.
http://www.c5forum.com/diy/fog_lamps.php
Old Nov 13, 2004 | 05:09 PM
fdxpilot's Avatar
fdxpilot
The two types are 885 and 893. I can't remember which is which, but the brighter bulb is the same one as my 94 Z28, so look for 94-97 Z28 Camaro, and you will get the brighter 50W bulb. It helped in my vette. Not as bright as PIAAs, obviously, but much cheaper, and easier.
Old Nov 13, 2004 | 09:18 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
It does make a BIG difference. I'm sure not as much as better bulbs but it'll help.
Mark
Old Nov 13, 2004 | 09:33 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Old Nov 14, 2004 | 02:06 PM
Paras's Avatar
Paras
Following with the theme above, I actually adjusted my headlights up a little cause they didn't go out far enough and... *poof*! Now when I turn on my fogs, I can see them--its just that my headlights were overlapping where the fog lights were shining... Now the headlights and fog lights actually illuminate different areas!
Old Nov 14, 2004 | 03:55 PM
screw991le's Avatar
screw991le
And how did you adjust your headlight, you need to tell all.
To Stock fog lights
