Trans greasy
Old Nov 13, 2004 | 10:08 PM
00hotvette's Avatar
00hotvette
Default Trans greasy
I removed my rear tire today and noticed that the trany looked real greasy. Its a auto is this normal? When should the seals be replaced?
Old Nov 13, 2004 | 10:11 PM
You will get some grease build up through normal wear and tear on the car. If it gets to be excessive, or if you see wet spots either on the part or the floor, then you may want to get it looked at.
