under hood dome light
Old Nov 14, 2004 | 07:04 PM
Jetsalot777's Avatar
Jetsalot777
Cruising
Default under hood dome light
my under hood dome light is not working, I have changed the bulb #(561) I did not see anything in the owners manual pertaining to a fuse for the light, any sugestions?
Old Nov 14, 2004 | 07:10 PM
Tombone's Avatar
Tombone
Check the connection plug in. I believe it’s around the side of the radiator.
Old Nov 14, 2004 | 07:14 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Check and see if the connection is corroded if so take some sandpaper to the connection.
Old Nov 14, 2004 | 08:55 PM
Blue Lion's Avatar
Blue Lion
Do a search on this topic. It gets brought up every so often. Mine doesn't work either and it's not the bulb, connection, or fuse. I gave up on it as everything else on the car works.
Old Nov 14, 2004 | 09:07 PM
Wontspeak's Avatar
Wontspeak
2017 C5 of Year Finalist
Default Under Hood Lamp
Try turning on the parking lights.
Old Nov 14, 2004 | 09:44 PM
dbirdhouse1's Avatar
dbirdhouse1
Mine was due to corrsion on the ground wire...cleaned and connected, no troubles since then...............
To under hood dome light
