2000 vert antenna inop
Old Nov 14, 2004 | 08:05 PM
Marathon26's Avatar
Marathon26
Default 2000 vert antenna inop
The antenna will not fully retract on my 2000 vert. It will go up all the way, but only goes down about 1/2. I can push it the rest of the way with relative ease. I tired the fix shown in 2000: Service Bulletin: Power Antenna Not Working Properly or is Completely Inoperative. I replaced the )-ring Assembly/Cap Nut as suggested, but that did not cure the problem. The owner's manual indicates there is a kit that may cure the problem. Has anyone experienced this problem and what did you do to fix it?
