Question about Macleod clutch
Old Nov 17, 2004 | 10:13 PM
mitymikec's Avatar
mitymikec
Default Question about Macleod clutch
i have a twin disc set up..the pedals varies from time to time..when i pull the shifter out of gear i really need to pull on it and other times in is smooth as can be..another problem is that when the car heats up it gets harder to put the car into reverse..if i have fresh fliud in it, it seems to work better than if the fluid has been in there for a while..i have bled the system, installed a new slave cylinder, i have the macleod master and i am out of ideas on what to do next..if i replace the fluid the shifting is smooother and as the days go on putting it into gear gets hard and notchy..the clutch does no slip and is still holding great..the pedal never feels great..it seems like it drags a liitle and i think this is because it is not releasing completely..i notice that if i press the clutch in on a gradual slop the car does not move as qiuck as if i put it into neutral..input is greatly appreciated..
Old Nov 17, 2004 | 11:23 PM
mitymikec's Avatar
mitymikec
ttt
Old Nov 18, 2004 | 11:29 PM
mitymikec's Avatar
mitymikec
ttt
To Question about Macleod clutch
