tire sensors...
Old Nov 18, 2004 | 06:01 AM
jman1's Avatar
jman1
Default tire sensors...
how accurate are they?? it seems that since it started getting cold the low tire pressure warning keeps popping up on the dic...I'm thinking it's the cold air but just wondering if thats a sign of a bad tire sensor
Old Nov 18, 2004 | 06:23 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
They seem pretty accurate to me. I bought one of those Sears digital tire pressure gauge thingies and it reflects what the DIC says the tire pressure is.
Might be a bad sensor, as you said... maybe... I have no clue
Old Nov 18, 2004 | 06:25 AM
Patman's Avatar
Patman
Don't forget that your tires will lose about 1psi of pressure for every 10 degree drop in temperature. So if you set them to 30psi on a 90F day, you'll be at 25psi when it's 40F outside. So the sensor probably isn't bad, you just simply need to adjust your pressure higher for the colder ambient temps.
Old Nov 18, 2004 | 06:26 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
The most difference I've noticed from any hand held gauge is about one pound. Close enough for daily use.
Old Nov 18, 2004 | 06:30 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It could just be cold temps lowering your pressure.
Paul
Old Nov 18, 2004 | 06:47 AM
From what I can tell, they are farily accurate. At least mine seem to be when I check tire pressure with a digital guage and then get the readout from the sensors.
Old Nov 18, 2004 | 09:21 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Mine have always been pretty accurate ... as others have said I've only seen a 1 pound difference on occassion.
If yours are showing different from a good tire gage I would check out the sensor. If you are simply seeing a drop in pressure I'd say it was temp related.
Old Nov 18, 2004 | 09:51 AM
roscoe118's Avatar
roscoe118
If you look at the readings on the DIC, do all 4 tires read the same pressure? If so, then it is the cold weather, as I doubt all 4 sensors would go bad at the same time.
To tire sensors...
