Pully squealing?
Old Nov 18, 2004 | 02:56 PM
diyguy's Avatar
diyguy
Default Pully squealing?
99 C5, MN6 - 50K mi
Got a pulley or idler squealing, but can't identify which one? It is not the belt slipping - definately a metal to metal type squeal.
What would be most likely? Water pump? Idler, Alternator?
I will get my broomstick out later and go for the close-in hear stick test. It's been sitting for about a week now and it's noisy and does not for a vette sound like it should!
It is continuous and parallels engine RPM.
Anyone with anything similar? A WD40 fix or replace a bearing?
Old Nov 18, 2004 | 03:07 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
um... how about letting the pig out from under the hood?
Old Nov 18, 2004 | 05:31 PM
Vette '01's Avatar
Vette '01
Default Mine was doing the same thing....
My 2001 with 39,800 miles was doing the same thing. Took it to the dealer and it turned out to be the a/c belt and a/c belt tensioner.
I had them both replaced and it's doing fine now.
Old Nov 18, 2004 | 08:51 PM
slicksilver11's Avatar
slicksilver11
Could be several things....
I just replaced the belt, main tensioner, the idler pulley, water pump...
Still was squealing. Got a gator back Belt - no more problems----
I will have to wait and see.
All of the pulleys see to be straight thus keeping the belt true. if not it might be the other two mentioned - power steering pump or the alternator.
Old Nov 18, 2004 | 09:12 PM
GrayC5's Avatar
GrayC5
Idler pulleys and tensioner pulleys are both known to have bearings go bad. There is an idler pulley and a tensioner pulley on both the main drive belt and the A/C belt. Good luck with the problem/fix.
Old Nov 18, 2004 | 09:15 PM
NSTG8R's Avatar
NSTG8R
Old Nov 18, 2004 | 09:17 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Are you sure it's not the squealy pulling??
Old Nov 18, 2004 | 09:21 PM
GrayC5's Avatar
GrayC5
This just now came back to mind: 1997-1999: Service Bulletin: Accessory Drive Squeak (Replace Idler Pulley)
To Pully squealing?
