Wind Noise on Driver's Side Window
Old Nov 18, 2004 | 03:28 PM
tbgunn24's Avatar
tbgunn24
Default Wind Noise on Driver's Side Window
I"ve noticed that where the window closes against the driver's side, there's now a small gap between the window and the black "insulation"? I recently noticed it and thought it was how I had replaced the roof panel. After trying numerous times with the roof, the gap is still there and there's even a little water getting in. It's new, 2,000 miles only, so should I go to the dealer and get it fixed or is there something I can do to remedy it myself?
Thanks to all
Old Nov 18, 2004 | 03:33 PM
NSTG8R's Avatar
NSTG8R
if your talking about the place I think you're talking about right up near the A pillar then I believe new weatherstripping is in order. However, I could be wrong. Go talk to the dealer or a competent local mechanic.
Old Nov 18, 2004 | 03:48 PM
_Redline_'s Avatar
_Redline_
I used to get wind noise when over 100 mph from the windows. There is a black tab on the roof that you may need to adjust. I had to adjust mine.
I'm note sure if that is your problem, but you may want to check it.
Old Nov 18, 2004 | 03:50 PM
ALLEGRO's Avatar
ALLEGRO
Try adjusting the roof first, then maybe the window itself if that doesn't work.
After that I would have it done at a dealer. Needs to be addressed!
Old Nov 18, 2004 | 10:58 PM
American Dream's Avatar
American Dream
I had the same problem with my 04 coupe. I brought it to the dealer, they adjusted the window pitch, and it was tight against the weather stripping after that. No leaks, no noise. -AD
Old Nov 19, 2004 | 04:20 AM
markcz's Avatar
markcz
Click here for the window Tip-In adjustment procedure.
Old Nov 19, 2004 | 06:07 AM
Lancer033's Avatar
Lancer033
Thanks to all
I've had the same thing on mine since it was new. The dealer said it would take close to a week to fix , so i decided that I'd rather live with it because it's not that bad and I really don't care about the noise. I do get a little water in at some speeds in heavy rain, but not enough to worry about.
Old Nov 19, 2004 | 06:32 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Thanks to all
I would say if you've got a gap, wind noise and water getting in you are a prime candidate for the window tip in adjustment. You can find a very good write-up on how to do it here:
http://www.johndennington.com/
Visit the Corvette site, then click on the "How To's" in the left pane then select the "Window Tip in Adjustment" it takes about 10 minutes to complete and about 1 minute each if further adjustments are required. I can all but guarantee that this will fix the issue.
Paul
Old Nov 19, 2004 | 07:49 AM
Tom/99's Avatar
Tom/99
I have some wind noise on the drivers side, with the glass top, not the painted top. I guess it just needs to be adjusted.
Old Nov 19, 2004 | 09:58 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
When you put the top back on be sure the w/s on the piller overlaps the top w/s at the rear corner.
To Wind Noise on Driver's Side Window
