Which fuse in the owners manual is for the vanity mirrors and engine compartment light? I know its a mini 10 AMP. Which fuse box? It says its in the instrument panel electrical center. Thanks in advance
John
Fuse 2 - it is not listed in the owners manual so I checked the wiring diagrams. Both also go through micro relay 37, so there is a chance that could be bad - try fuse 2 first.
This fuse box is behind the passenger's foot rest - there are two latches that you pop open, then you wiggle the foot rest out and you'll see the fuse box.
