Help...broken exhaust pipe
Old Nov 19, 2004 | 08:43 PM
Will99FRC's Avatar
Will99FRC
C7 of Year Finalist (stock) 2019
Default Help...broken exhaust pipe
The drivers side exhaust pipe has broken away from the 2 bolt flange just after the cat. Can this be repaired? Or will I need to replace piping from this flange back. Any help is appreciated, Thanks
Old Nov 19, 2004 | 08:55 PM
ROJ#79's Avatar
ROJ#79
I had the same thing happen on my '99.
I bought and installed the Corsa X pipe. It's a good fix and not to hard to install. It will bolt up to your stock or custom exhaust Mufflers.
Old Nov 19, 2004 | 09:03 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
common problem..this can be welded..but like other I went with a stainless steel Corsa X pipe guaranteed for life.
Old Nov 19, 2004 | 09:20 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I'd go to a muffler shop. They should be able to weld it. Unless it's rusted beyond repair. Keep us posted.
Old Nov 19, 2004 | 09:42 PM
USA-VET's Avatar
USA-VET
Old Nov 20, 2004 | 03:26 AM
99PewterVette's Avatar
99PewterVette
I had the same thing on the same side, Corsa X pipe is the answer!
Old Nov 20, 2004 | 05:45 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Happened on my 98, had Tuffy weld it, took about 20 minutes. another common probelm that GM ignores...
Old Nov 20, 2004 | 06:47 AM
C5naples's Avatar
C5naples
Same thing happened to me, I took it to a muffler shop. They told me they fix them all the time. Cost me $40. They also checked the other welds as well.
Old Nov 20, 2004 | 08:44 AM
Yes, it can be welded back on. Local muffler shop should be able to fix you up.
Old Nov 20, 2004 | 10:12 AM
MSGvette's Avatar
MSGvette
Old Nov 20, 2004 | 10:27 AM
G-lock's Avatar
G-lock
Take it to the dealer, the H-pipe is warrantied for 8 years/80,000, let GM pay! But rather than fight them, get it welded. Jeff
Old Nov 20, 2004 | 02:50 PM
MalaysianMenace's Avatar
MalaysianMenace
99 was a bad year for exhaust flanges
I have a 99 coupe. I had the flanges break on each side at different times. An exhaust shop repaired the exhaust flange for $50 each side.
Not a bad repair cost - but do yourself a favor and get a new exhaust anyhow and cosider it a $50 discount
Old Nov 20, 2004 | 04:50 PM
servohead's Avatar
servohead
Yup I just welded mine back together man. Go to it or junk the stock catback for some real mufflers!
Old Nov 20, 2004 | 06:06 PM
LoneStarFRC's Avatar
LoneStarFRC
True story!
Old Nov 21, 2004 | 12:29 PM
Will99FRC's Avatar
Will99FRC
Well, I took it to the local muffler shop. They rewelded the pipe to the flange, only cost me $70. He said the original weld was very poor. This will buy me some time until I get a new exhaust system. Thanks for the help eveyone.
To Help...broken exhaust pipe
