Option Code Locations Class 101
Old Nov 19, 2004 | 10:34 PM
Gofasterdad's Avatar
Gofasterdad
Default Option Code Locations Class 101
I'm new here and I'm too lazy to search for the thread. Please forgive....
The owner of a 99 vert that I’m interested in (300 miles away) can’t make out the option code numbers in the glove box. Probably smeared away by the owners’ manual. Is there another place they can get those codes for me on the vehicle so I know exactly how it’s equipped? (no original sticker or build sheet either)
Thanks.
Old Nov 19, 2004 | 10:47 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Your best bet maybe to send a PM to Sponge vette with your VIN and he could look it up for you
Old Nov 20, 2004 | 07:55 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
In addition to SpongeVette, you can purchase a duplicate of the original window sticker and buildsheet from the Corvette Museum.
https://www.corvettemuseum.com/libra...ts/index.shtml
Paul
Old Nov 20, 2004 | 08:01 AM
talon90's Avatar
talon90
NCM Ambassador
If time is an issue, might be able to get a local dealer to print out the RPO information and the service history with the VIN.
Old Nov 20, 2004 | 08:35 AM
A dealer could print them out based on the VIN or Sponge Vette may do this for him. Good luck with the Vette.
Old Nov 20, 2004 | 03:04 PM
HummelS's Avatar
HummelS
Someone can correct me if I'm wrong, but I don't think they moved the sticker to the glove box until 2000 MY. They should be on the inside of the left storage well cover on a '99.
Old Nov 20, 2004 | 03:09 PM
talon90's Avatar
talon90
NCM Ambassador
Good point, when he said smeared I assumed he found the label and just couldn't read it. I never even thought about the cover...that's where they are on my '97.
Paul
Old Nov 20, 2004 | 04:00 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have a 2000 with a biuld date of 8/99 and mine is in the glove box.
Old Nov 20, 2004 | 04:36 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Thanks.
Here are the options for the 1999 Model,
Options for 99 Vettes Hopefully you know what options your vette has.
Old Nov 20, 2004 | 06:18 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
my 1999 has it in the glove box. My Build date was 1/14/199
Old Nov 20, 2004 | 07:31 PM
Sponge Vette
I've never seen them post the Birth Date anywhere in the vehicle, i'd be suprised if your Built date was has you posted. Post the last 8 digits of your vin# and I'll check for you.
Old Nov 20, 2004 | 07:35 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Got mine off the build info you gave me not on the glove box
VIN 1G1YY22G1X5117478
VEHICLE BUILD
Merchandising Model : 1YY07
Gross Vehicle Weight Rating : 1699 kg (3746 lb) Order Number : 122FM3
Build Date : 01/14/1999 Build Plant : 1X5Y - BOWLING GREEN
Old Nov 20, 2004 | 08:13 PM
Sponge Vette
For some reason, I thought some one posted that their built date was in the glove box.
To Option Code Locations Class 101
