Engine compartment cleaning instructions
Old Nov 21, 2004 | 01:07 AM
vette99coupe's Avatar
vette99coupe
Default Engine compartment cleaning instructions
I tried to search for a previous thread on this subject but couldn't find one.
Can someone give me some hints/instructions on the best way to clean up the engine and
surrounding compartment area under the hood. I know some of you must have
developed some interesting methods to clean various areas under the hood.
Thanks for the help
Old Nov 21, 2004 | 01:38 AM
GrayC5's Avatar
GrayC5
Here's a few recent threads on the subject:
Cleaning Engine Compartment
Wanna clean my motor!
Also, these type questions/topics are sometimes better asked in the Car Care Products section of the Forum. Several knowledgeable people hang out there and they may be able to provide you with better answers to these type questions.
Good luck!
Old Nov 21, 2004 | 04:18 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Light mist, sponge & soapy water, california duster, depends on the filth.
Old Nov 21, 2004 | 06:50 AM
C5naples's Avatar
C5naples
My engine compartment was very dirty when I got the car. I used no water. Blew it off with compressed air and started wiping it down with simple green
Old Nov 21, 2004 | 07:34 AM
I wipe down my engine compatment every time I wash the car. I use an old Absorber to get the dust off, and if there is any grime that won't just wipe off, I use a rag with some Simple Green on it. I've never sprayed water on the engine, although there are some that do this using very low pressure.
Old Nov 21, 2004 | 11:29 AM
Z06-JIM's Avatar
Z06-JIM
If engine is real dirty/greasy, I cover the alternator and spray on Simple Green. This is after I've warmed the engine a couple of minutes.
Then, I close the hood and let this set a couple more minutes and
lightly mist off with garden hose.
I use an old towel to wipe everything off and dry with.
If engine is just dusty, I'll lightly mist with water and wipe down with the towel.
Once engine bay is clean, you can just wipe it down weekly with a damp towel to keep it looking good.
I know there's a lot of pros and cons in using method but I've never had a problem and it works great for me. You just have to use common sense with the water and be sure to thoroughly rinse off the Simple Green.
To Engine compartment cleaning instructions
