Stainless Steel Inserts
Old Nov 21, 2004 | 09:41 PM
JNS's Avatar
JNS
St. Jude Donor '06-'09
Default Stainless Steel Inserts
Hi. I'm thinking of getting some stainless inserts for front and rear and was wondering if there is any particular brand I should stay away from because of bad fit. Also, I don't want any that are too shiny (chrome look). I'm considering the ones by SS Inserts. Anyone have these?
Thanks,
Jeff
Old Nov 21, 2004 | 09:43 PM
Rage@AutoBuffs's Avatar
0Rage@AutoBuffs
Former Vendor
St. Jude Donor '10
I have them and love them. Great quality
Old Nov 21, 2004 | 09:51 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Get the SS Inserts, they are #1.
Old Nov 21, 2004 | 09:56 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
I didn't do the front because I didn't want them to get all chipped up from rocks and such.
Old Nov 21, 2004 | 10:06 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I have the SS Inserts (brand) front and rear. The fit and quality is the best.
No worries, Barry will take care of you.
Old Nov 21, 2004 | 10:08 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I got my chorme ones from MidAmerica and they are fine.
Old Nov 21, 2004 | 10:19 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Got mine from Corvettes Of Houston - was very happy and will have the body shop order another set from them for my new backend...
Old Nov 21, 2004 | 10:53 PM
2REDS's Avatar
2REDS
Old Nov 21, 2004 | 11:16 PM
JNS's Avatar
JNS
Thanks for the replies, gang. PTdrummer54, I'm going by Corvettes of Houston tomorrow so will stop in and check theirs out. From the description on their website it almost sounds like they may be selling the ones from SS Inserts. We'll see.
Jeff
Old Nov 22, 2004 | 12:31 AM
BigJoe's Avatar
BigJoe
SS Inserts stand behind their product. Lose or damage one he will replace it. But don't worry it is hard to do either if they are installed correctly.
Old Nov 22, 2004 | 12:45 AM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Mine survived a dead on 25 - 30 mph impact from a full sized pick up - not one came loose - anyone interested in a slightly used set (some disassembly required)
And I suspect that SS Inserts is COH's supplier...
Old Nov 22, 2004 | 12:55 AM
gmosley's Avatar
gmosley
Default glad to see this post
im glad to see this post considering ss inserts is the cheapest prices ive seen to date for the letter sets in stainless
been thinking of getting some and well now im sold as far as the quality and fit go
thanks for all the indirect help
Old Nov 22, 2004 | 01:17 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Here are a couple of install tips
http://c5.techbottle.com/ssltrinstall.htm
Old Nov 22, 2004 | 07:09 AM
The ones by SS Inserts are top quality. You won't be disapppointed by them.
Old Nov 22, 2004 | 09:35 AM
Z0SLIK's Avatar
Z0SLIK
Old Nov 22, 2004 | 09:38 AM
JNS's Avatar
JNS
Thanks for the tips, Sully. I was kinda wondering about the best way to install them.
Jeff
Old Nov 22, 2004 | 09:39 AM
diyguy's Avatar
diyguy
Does anyone have the website for SS Inserts?
And, would the SS look good on white?
To Stainless Steel Inserts
Old Nov 22, 2004 | 10:16 AM
Sully C5's Avatar
Sully C5
Jeff
Old Nov 22, 2004 | 10:24 AM
gmosley's Avatar
gmosley
Default website
the website is the name ssinserts.com
Old Nov 22, 2004 | 10:33 AM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
As Sully pointed out careful prep will ensure a successful install. In addition to cleaning the area, I would also suggest that you dry fit each letter first, epecially the more complicated ones like the R. Make sure they will fit flush before you add adhesive - if you have to do minor reshaping to make that happen then go for it. Once they dry fit correctly then go for the adhesive.
