Just saying hello, asking a loaded question
You can get to 425-430 rwhp but remember that you may have to upgrade the clutch - output shaft - etc.
Also remember that when you get to that hp mark it won't be enough and you will be going into the car wholesale.. This is just situation I am encountering right now!!
It is fun though
If i were you...look into the Procharger...and get a tuner to do some work with it afterwards...as long as you run a safe air to fuel ratio..you are good to go...i would atleast recommend changing the pushrods...the stock LS1 pushrods were usually considered the weakest link in the motor..the rest of it will hold up fine...they will usually hold up for quite some time but you never know when one might get bent...
Josh
Now you're getting a Vette too? Lucky!
My question is, what are the best bang-for-the-buck packages you can think of off the top of your head. Just looking to get general ideas, as I plan to do a LOT of research and reading as the time to actually start this project draws nearer. I know that I already like the BB&B bullet exhaust
, but that's about as far as I've gotten toward having a specific list of parts in mind.Lingenfelter promises 500bhp, but I have to believe you can get there for less than that price premium.
Also, what should be the single biggest concern about running that sort of power through the 99's engine/driveline on a daily basis? Does this package have a particular weakness I should look out for? Any serious replies and non-flames will be appreciated.
Thanks for reading!
One thing I have noticed is that the Corvette crowd, much like the Impreza crowd, is more friendly than most enthusiast groups. Look forward to posting here.
Purerock - I'm actually not too far from St Pete...live up in the Palm Harbor area. The next time you are having a meet, please PM me, as I'd like to attend! I have a friend who's dad collects/restores/races Corvettes. If you've been to Sunshine and spotted a BEAUTIFUL red '56(I think) tube chassis car, you've seen his dad. He's the one who has turned me onto LS1s and is bringing me back into the domestic fold, so he'd probably come along as well. His racecar is a yellow/black-striped 69 Camaro SS that has also seen a few laps at Sunshine. Both are nice cars, but his dad's is just stunning!
talon90 - I wish I could!! Need to get my finances in order so that I have everything the way I want it before taking on yet another project.
3XBlack - We get a lot of those stories over on NASIOC.
Some kid gets in an AWD car and thinks he's Petter Solberg. Always sad to see a Scooby go down...hope no one was hurt in that accident. I've heard AWD is great fun in the snow...thankfully I'll probably not ever know.
Ruby, yelo, xcesive - Thanks for the welcomes and yes, I am well aware of how these car projects can spiral out of control REAL fast. The WRX went from a "300bhp, some nice wheels and springs" thing to turbo swapped, coil-overed, forged AL, big brake money pit. I love it, but I'm also done with it...for a good long while anyway. Could swap up to the STi 2.5 shortblock and really start making some power, but that's a lot of work and more dyno/tune time I'd rather not purchase at this time.
Paras - The math actually comes out to ~395bhp/290awhp(at 26% drivetrain loss, which is the WRX's accepted standard). The power was safe, the car ran super strong...until I screwed with the flywheel and put a 12lb unit in to replace the stock 26lb piece. I was doing a tranny(cryo'd)/clutch swap and figured the flywheel would be a good idea to put more of those HPs to the ground. Put it on as an afterthought and within a month the car was throwing mifire codes on all cylinders randomly...sometimes 1, 2, 3, 4 or a combination of any of the above!! Needless to say, I was worried. It turns out the lightened flywheel goofs up a set of sensors that watch for expected crank/piston velocities at particular RPMs. The problem is present in the low range, as misfire codes have always occured while pulling away gently from a stop. The car eventually put itself in safe mode, where I have left it until I can get the flywheel swapped back to stock...hopefully tomorrow. As for the actual tune, I did the usual turbo/FMIC/catless header-back/rails/injector/pump/ECU reflash that has become pretty standard with our cars. Air fuel ratios were always stinky rich (my exhaust outlet looks like a coal miner's lungs) and I have not ever experienced any lean conditions with the car. The highest EGTs I have ever seen were around 1400degF and that was at a prolonged 90mph cruise up the interstate. Car has a fairly safe tune, but we all know there are no guarantees with these things. A STi 2.5L shortblock (forged crank/con-rods/cast pistons) runs around $1300 brand new, so popping this motor wouldn't be the end of the world, but I haven't ever felt worried about it. The point of all that typing: I'd be happy to help your friend or point him in the right direction. Let me know.
Wow...that was a lot of typing.
I'd like to attend!
House. Probably not this Friday with the holiday and all, but will
PM you as to the next one. Also be sure to peep the SouthEast
section for events...lot's of Florida goings' on.
I wish you luck and hope you get there, but did want to inject a little reality into the subject...for what it is worth.
Just to make sure, I do plan on doing heads and cams on top of the headers, hi-flo/no cats, a good cat-back setup along with a CAI of some sort. Maybe add push rods and valve springs to that equation as well. Still seem unreasonable?
:rtpilot - Thanks!
Very Expensive if naturally aspirated? Sure.
Awesome sound? Sure
Lumpy idle? Sure
No vacuum at cruise? Sure
Poor driveability? Sure
Expensive to tune? Sure
Worth the trouble? Sure
Cheaper and easier ways to achieve what you need? Sure
For myself, for example, I wanted a canyon crawler that I could also cruise at very low speed, was fine in traffic, would not overheat, was loud but not attract every SWAT team from 100 miles around, and had awesome top end. Wasn't trying to smoke the tires, didn't care about trying to holeshot some AWD Ricer, don't care about quarter mile times or gas mileage etc. etc. etc.
Point is - just shooting for a Braking Horsepower number is only a small part of the equation.
0.02 cents deposited - your mileage may vary.
EG
http://www.diecast-pub.com/forums2/i...howtopic=17718
He was from VA, what did you expect?
Seriously though, welcome to the forum, you'll absolutely love the Vette over the WRX. There's nothing wrong with the WRX, there's just something cool about being in a vette. (talking about handling/power/comfort, etc, etc)
I agree with the rest of these guys. 500 BHP is easy to obtain, I have an appt with a local speed shop to install a Maggie s/c (went with maggie since it is my daily driver... no fuss/no muss), I'll have just about 4K-4.5K in it including installation.
Someone previously mentioned NOS/superchargers were like being on steroids. It's funny, I use that analogy but not for s/c's. To me, NOS is like being on steroids, you run out of juice, it's like running out of pills.
You never run out of being supercharger....
Anyway, welcome to the forum and enjoy your vette when you find it. (May wanna look at a convertible
Mark
I'll give up a little on the comfort/refinement side for more power. If you had the chance to ride in my Subaru, you'd understand how little I care about creature comforts and civility.
I did a lot of research before starting my mods and knew, more or less, exactly where I would end up and how the car would behave. Plan to do the same in this instance. The beauty of it is, the modes for Corvettes are not much more expensive than what you would see in Subarus. Hell, there was a time that Subaru stuff was so rare in the States, people were paying $1000 for polished HKS headers that were not even equal length! It was nuts.No verts for me, has to be a FRC unless I find something special in a regular coupe. I like closed roof cars. The Maggie sounds interesting...one more option to look into.
Thanks for the info and thanks for the welcomes! There are always going to be varying opinions on performance mods, etc. The consensus seems to be that 500hp on motor is feasible for a street driven car.
Please keep sharing info and experiences, as it may be benefiting more people than just this noob.
Good luck and welcome
