Great price, great product. You will get rust where the pads wear, no way to stop that since the zinc wears off that area. However, drive a short distance, and the rust is gone.
They look great, they will show rust when you wash them, but rub off first use.
Great Brakes!!! TIP: If you don't race the car or drive real hard on the street, you may want to consider drilled only, as the slots are designed to shave away a small portion of the pads each time the brakes are applied. I'm using the Sportbrakes drilled/slotted with factory pads on my '99 and they are fantastic - not a whole lot of dust either.
