lowering question
Old Nov 22, 2004 | 10:11 PM
STEEL's Avatar
STEEL
Default lowering question
i just lowered my 99 FRC and i cut the first bushing in the rear. the front i lowered using the bolt. i know it takes time to settle but the rear is about an inch lower. i want the front to be lower is their a bushing up front i could cut to get it lower in the front and if so where is it. any info would be great
Old Nov 22, 2004 | 10:21 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
No need to cut the rear bushings...the stock adjustment will usually put the rear lower than the front anyways.
Yes, there is a front bushing, and it's attached to the bottom of the front bolts. This tech tip show's what's involved to remove the bolts and cut the bushings.
https://www.corvetteforum.com/techti...D=90&TopicID=1
Many, like myself, have just jacked up the spring enough to saw the front bushing off with the bolt in place. It requires no dissasembly, but you'll need something like a hydraulic spreader to spead the spring up high enough to access the bushing under the spring. Not the safest method, but if you have the tools and are aware enough to never ever put your hand under the spring when it's jacked up, it saves a lot of time.
Old Nov 22, 2004 | 10:57 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
I had cut front bushings on mine.Last weekend I pulled the front adjuster bolts out.Only lowered it 1/4+" so coilovers are one the way.You can get low with cutting the front bushings and longer bolts in the rear.
Old Nov 23, 2004 | 01:27 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I just dropped mine on Sunday on stock bolts with no cut bushings and I am waiting for it to settle. So far (160miles) it is way too high.
If it's not down by Friday - longer rear bolts and cut front bushings this weekend.
EG
EDIT - Here is my Vette "settled" - still too high...
Old Nov 23, 2004 | 04:58 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
just couldn't wait could ya...
http://www.z06vette.com/diy_lower.php
Old Nov 23, 2004 | 05:15 PM
STEEL's Avatar
STEEL
no i guess pacents is not one of my virtues :o
Old Nov 24, 2004 | 12:32 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Lowest Corvette
Old Nov 24, 2004 | 10:45 AM
Slammed Vette
Chopped!!!!
Old Nov 27, 2004 | 07:52 AM
MiamiDave's Avatar
MiamiDave
What do replacement bushings and bolts go for? I've heard you have to purchase like a whole front ent for a lot of money...
Anyone just cut 1/3 of the bushing...? I'm only looking for a .25-.50 drop in the front...
Old Nov 28, 2004 | 06:55 PM
STEEL's Avatar
STEEL
Thanks for the info I cut the entire bushing of the front bolt and the front is now lower then the rear and looks great i will post pics when i get my camera
Old Nov 28, 2004 | 08:00 PM
MiamiDave's Avatar
MiamiDave
How's your ride...?
Old Nov 28, 2004 | 08:02 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Originally Posted by mikes99corvette
Old Nov 28, 2004 | 10:54 PM
KamPow3r's Avatar
KamPow3r
Thats photoshopped!
Old Nov 29, 2004 | 12:04 AM
Dirty Howie's Avatar
Dirty Howie
Commmooooon......do you realize how long it will take a snail to make a detour around your car don't you have a heart
Old Nov 29, 2004 | 12:08 AM
Dirty Howie
Originally Posted by MiamiDave
How's your ride...?
Looks like I have to have mine cut also. But it does concern me how this affects ride/handling. Also is there any premature wear of any associated parts.
Old Nov 29, 2004 | 11:35 PM
STEEL's Avatar
STEEL
The ride is alittle more harsh but the handeling has incresed. the olny thing is my plastic spoiler underneath scrapes under every speed bump. but it looks awsome.
To lowering question
