Too Much cold air?
Old Nov 23, 2004 | 08:57 AM
DC-STRO's Avatar
DC-STRO
From: After reading this thread, I gotta tell ya... you're an ass. .
St. Jude Donor '05-'06-'07-'08-'09-'10-11-'12-'13
Default Too Much cold air?
Living in Minnesota this time of year every ride could be your last one. I have noticed that the colder it gets the engine gets more powerfull. With air temps around 30* and low humidity the Ls1 SCREAMS!
I have a Vararam, so I know that I am pulling lots of cold air in.
Can too much cold air harm the engine?
Or what tempature is too cold?
Keep in mind I do get the engine up to temp before I take it out.
Old Nov 23, 2004 | 09:00 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Yeap The LS1 (and most other engines) loves the cold air..so long as you get up to operatring temp I don't think too much cold air could be bad but I am sure someone will disagree
it's too bad they throw so much friggin salt on the roads otherwise I would drive mine more during the winter
Old Nov 23, 2004 | 09:10 AM
AFVETTE's Avatar
AFVETTE
I've driven my Z with a Blackwing in temps below ZERO and the car loved it. Only problem was traction, frozen tundra and ice cold GY F1's equal ZERO traction. I was out showing my broth-in-law the car one morning and even at 40 MPH I could feel the car was basically in a four wheel drift taking corners. After a while I got comfortable (and I guess the tires warmed a bit) I was able to get a little more agressive. He has a V-12 Jag and the first time he rolled into the throttle on my Z he almost lost it (thank god for TC/AH and the fact he's a good driver used to Wis conditions). Once he found the limits he was having a ball. He hadn't driven a vette since the 60's. I was impressed.
Cold is good.
Tom
Old Nov 23, 2004 | 09:12 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
They do love the cold. I seem to remember reading that it is something like an additional 1.3Hp per 10 degree temperature drop...not sure if this is exact, but close. I can't imagine a scenario where you can get too much cold air. I mean maybe -50 F. air temp would be rough on a cold start engine but I don't think you'll damage it driving a warmed up engine during the winter months.
Paul
Old Nov 23, 2004 | 12:08 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just don't do the TB by-pass mod and you'll be all set. The TB had a heat line that helps condensation on the throttle plates and helps the car get to operating temp quicker. (from what I understand from here)
Old Nov 23, 2004 | 01:07 PM
You should have no problems with cold air. These engines really perk up when it gets cold.
Old Nov 23, 2004 | 01:20 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
When it gets so cold that the battery can't crank you over, then it's too cold
The only thing you have to do is be more patient while oil temp comes up.
Old Nov 23, 2004 | 01:29 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Can't wait to drive mine this winter.
Old Nov 23, 2004 | 01:30 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
If it will start, it's not too cold. The Fuel Injection System compensates for the changes in air density. More air = more power.
Old Nov 23, 2004 | 01:32 PM
Sorny's Avatar
Sorny
I tell you what, I'm darn glad to be still driving Betty this time of year. Once the white crap falls from the sky, it'll be a long wait.
Sunday, I went for a cruise, and managed a whopping 9.6MPG. I guess I have been having a bit more fun with it knowing that every drive could be the last of the year.
Sorny
Old Nov 23, 2004 | 02:46 PM
corvettebob1's Avatar
corvettebob1
Paul
If I remember correctly it's 1.5% hp increase per 10 deg. F drop at the intake on a N/A engine.
And it's like 3% on F/I.
Old Nov 23, 2004 | 03:25 PM
stingray4me's Avatar
stingray4me
I think the best thing to do is what I'm going to do next year. Move to Florida !
To Too Much cold air?
