99 Column Question
Old Nov 23, 2004 | 01:13 PM
paul99's Avatar
paul99
5th Gear
Default 99 Column Question
Has anyone had issues after Steering Column Lock
My Column locked up 2 weeks ago.
It was towed to Dealer and Recall Service was performed.
It is an automatic.
Wanted to know if there is a chance of reoccurrence.
Old Nov 23, 2004 | 03:27 PM
kenrobb's Avatar
kenrobb
You must have a 6speed if it locked up after the recall done. On an auto they sustitute the locking plate with a spacer washer. So no way it can lock then. On 6speed the locking plate is still there. But new wiring harness/relay installed is suppose to prevent the column lockup. But guess it can still lock.
Old Nov 23, 2004 | 04:36 PM
roscoe118's Avatar
roscoe118
Paul, if you have an MN6, get a CLB and install it. Without it you are playing Russian Roulette, whether the recall has been done or not.
Old Nov 23, 2004 | 05:13 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It was probally never done in the first place, ask for a service record.
Old Nov 23, 2004 | 05:22 PM
Since your car is an automatic, you should not have any more problems with it after the recall. I think they put a plate in there to where the pin on the column lock cannot engage.
Old Nov 23, 2004 | 07:10 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
My 98 is an auto and no worries since the recall. The lock pin doesn't engage.
Old Nov 23, 2004 | 10:26 PM
ROJ#79's Avatar
ROJ#79
I had the recall done on my '99 auto and no problems at all.
Old Nov 23, 2004 | 10:38 PM
jrose7004's Avatar
jrose7004
I had the colmn lock recall done on my 98 a4 and the problem is history!
Old Nov 24, 2004 | 03:13 AM
mlumb's Avatar
mlumb
i have an auto over here in the UK.
can i do a mod on the lock myself or is it not possible?
mike.
Old Nov 24, 2004 | 07:09 AM
BiggieBoy's Avatar
BiggieBoy
Had the recall "fix" done to my '98 A4 a year and a half ago. No problems what so ever AND the steering column lock will NEVER lock again.
Old Nov 24, 2004 | 08:24 AM
paul99's Avatar
paul99
5th Gear
Default Thank you
Thanks for your help.
To 99 Column Question
