Installing Fog Lights
Old Nov 23, 2004 | 08:20 PM
2001 quicksilver's Avatar
2001 quicksilver
Default Installing Fog Lights
I have C5-01 that does not have fog lights. I want to put them in, has anyone put in a set of Fog Lights? Did you use after market or GM orginal parts? Looks like the wiring is in place but not sure, how can I tell? Know a good place to purchase the lights and switch? Thanks in advance.
Old Nov 23, 2004 | 11:36 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
look for Karstuffs, he'll hook you up.
Old Nov 24, 2004 | 02:11 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
See if this helps any:
https://www.corvetteforum.com/techti...=130&TopicID=1
Then you can go buy these (which are a bunch better than the stockers). They also have a mounting kit with brackets.
https://www.litewarehouse.com/catalo...products_id=28
Old Nov 24, 2004 | 08:57 AM
QuikZilver's Avatar
QuikZilver
Contact Tuan Le (forum member and works at supporting vendor, litewarehouse.com). He can hook you up with brackets and PIAA driving lights. Then pick up a Vert trunk/fog light switch from a dealer. Tuan can give you the info to install them. Also, there is a great Tech Tip here on the forum. Follow those directions and you can't go wrong!!
BTW, they look great!! AND, Tuan Le is a great guy to deal with!
To Installing Fog Lights
