DIC question
Old Nov 24, 2004 | 12:48 AM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
Default DIC question
After I filled my car up today, A message said " pull key and wait 10 seconds" What is that all about?
Shylor's Avatar
Shylor
Sounds like a column lock.
Old Nov 24, 2004 | 12:50 AM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
HOLY FLYING RAT DROPPINGS!! NO SHIAT??? Damn, does that mean it is going to happen or it did? It ran fine after that.
Old Nov 24, 2004 | 01:14 AM
GrayC5's Avatar
GrayC5
Possibly, but not necessarily. Several different conditions can cause this message to appear. For example, this message may occur when the ignition key is removed and reinserted before the steering column lock system fully locks or unlocks the steering column. However IMO, it would be advisable for you to read what your owner's manual has to say about this message.
Old Nov 24, 2004 | 01:15 AM
Shylor's Avatar
Shylor
Sometimes when the column locks people get that. If yours didn't, count yourself lucky. The computer may just have not been able to get the key chip information and reinstalling the key fixed things.
Old Nov 24, 2004 | 01:32 AM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
cool, thanks guys!
Old Nov 24, 2004 | 02:25 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Matt, just don't forget...when it does lock, just apply a solid pressure clockwise on your steering wheel, maybe even jerk it, while you turn the key on, hopefully that will keep you from being stranded at least.....i suggest ordering the columlock bypass, if i had 50 bux lyin around, i would
Old Nov 24, 2004 | 07:03 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Welcome to Column Lock Central. You're about to have one of the most aggravating experiences you can imagine. When you least expect it you'll try to start your and it will shut itself off and you can't turn your steering wheel. That's exactly how mine acted when it locked.
If you haven't and can get the recall work done - I'd suggest you take care of that before you get stuck somewhere you don't want to be or on a weekend when you can't get it taken care of.
Old Nov 24, 2004 | 07:39 AM
Shylor's Avatar
Shylor
Unless your car has a manual trans. Then the recall fixes nothing and the column can still lock. I also wouldn't get an aftermarket bypass as they can ruin your BCM. If you must use a bypass get GM's Harness K bypass. It is what they use to cure auto trans C5's column lock issues. It cost more than the aftermarket ones but, it sends the correct voltages to your BCM.
Old Nov 24, 2004 | 09:33 AM
vettenovice's Avatar
vettenovice
TTT
Is this true? I have a 2001 MN6 and plan to install the CLB when I take it out of hibernation in the spring. I don't wnat to screw up my BCM and run into further issues.
To DIC question
